98 honda accord 5 speed transmission lx
Old Jan 16, 2006 | 12:36 PM
edcpus's Avatar
Default 98 honda accord 5 speed transmission lx
the problem is i was driving one day and i was on the interstate, i was in fifth gear, meanwhile driving during around 75 the fifth gear just disappeared, however the rpm went up so i switch back to fourth and kept going. however, everytime i go into the gear all i get is rpm. Is it possible that the oil could be low in the trany, or do i just have a bad one, never had problems with the trany at all. can someone help
Old Jan 16, 2006 | 05:38 PM
hondadude's Avatar
Default Re: 98 honda accord 5 speed transmission lx (edcpus)
The description you give is a probable slipping clutch; go driving down the hwy at good speed then while holding the throttle steady 'bump' the clutch pedal ....if the rpms rise and stay high you need a clutch replacement.
Old Jan 16, 2006 | 05:40 PM
noobie's Avatar
Default Re: 98 honda accord 5 speed transmission lx (hondadude)
i am with the dude ,,
Old Jan 16, 2006 | 08:28 PM
edcpus's Avatar
Default Re: 98 honda accord 5 speed transmission lx (noobie)
no guys that didint work. nothing happen after i bump the clutch. any other ideas???
Old Jan 17, 2006 | 05:37 AM
notoriousB's Avatar
check the transmission fluid level before you drive the car more in case it is low on fluid. could be that simple. if not, sounds like your transmission could be going if this only happens in 5th gear.
if you stomp on it in, say, 3rd does it hold power the whole time?
Old Jan 17, 2006 | 06:57 AM
edcpus's Avatar
Default Re: 98 honda accord 5 speed transmission lx (notoriousB)
its manual so it doesnt have transmission fluid
Old Jan 17, 2006 | 07:12 AM
notoriousB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by edcpus &raquo;</TD></TR><TR><TD CLASS="quote">its manual so it doesnt have transmission fluid</TD></TR></TABLE>
quoted for future reference. that's almost sig-worthy.
are you ok? so you think a manual transmission runs dry?
hint: there is fluid in your manual transmission. it's called MTF, which is short for manual transmission fluid. check the level. have a nice day.
Old Jan 18, 2006 | 10:12 PM
edcpus's Avatar
of course i know that it has mtf, but how do i check it. i know it doesnt run dry
rkbowles
Jan 3, 2016 10:03 PM
SickSi99
Jan 29, 2014 04:01 AM
flyboy1
Transmission & Drivetrain
Oct 8, 2012 05:42 AM
97tegGS
Nov 24, 2005 01:44 PM
Greg James
Aug 17, 2004 06:05 PM
