timing belt tension questions
Old Jan 16, 2006 | 10:21 AM
andrey320's Avatar
Default timing belt tension questions
I was doing a valve adjustment on my car today and decided to check the condition of the timing belt. Visually, the belt looks great, but when I touched it - it felt very loose - maybe a whole inch deflection on exhaust side. (I have not changed or checked the the timing belt before) After I went through the procedure to tighten it, it felt slightly tighter. When I would turn the engine (by hand) the belt would feel loose on one side and tight on the other, turn engine - the other side gets loose... So that did not work.
Is my tensioner busted?
Could my belt be so stretched?
What is the specified tension? On which side?
How dangerous is it driving like this? (would the belt skip teeth or just slip?)
The car has 171k. mi. on it - I will probably change the t-belt, tensioner, and water pump as soon as I can. I would like to hear your opinions.
Thanks
(d16a6)
1990IntegraLS
Dec 17, 2016 04:30 PM
chahsiubow
Dec 14, 2007 10:01 PM
honda94accord
Apr 10, 2007 05:39 AM
JDMtype Eg6
Feb 18, 2007 05:45 AM
obd2gsr
Dec 21, 2002 08:53 PM
