i think i have a clutch problem
Old Jan 16, 2006 | 07:15 AM
No2Pencil's Avatar
Default i think i have a clutch problem
-stock- 90' crx HF b16a1 lsd obd-0
it all started a couple of days ago. i was in a McD's drive thrue when my clutch cable started to loosen. after i adjusted it, it would keep sliping more and more often. one of the last times i adjusted it the car wouldn't start, i have power... and its still wont start...
i have tightend it fully
i have loosend it fully
the pedal has tension when tightend
i ordered a new cable just in case but i doubt thats the prob now, or is it? help thanx.
Modified by No2Pencil at 8:40 AM 1/16/2006
Modified by No2Pencil at 8:41 AM 1/16/2006
Old Jan 16, 2006 | 01:10 PM
civicx's Avatar
Default Re: i think i have a clutch problem (No2Pencil)
what brand or clutch do you have? mabye you bought the clutch that is not good or it's depend on how you install them. if you didnt install right, it's will be a problem..
Old Jan 17, 2006 | 09:17 PM
jdeemseerx's Avatar
that kinda doesnt make any sense bc if you adjusted it to make it tighter and possibly adjusted it wrong then you would get the slipping your talkin bout cuz its stayin partially engaged.. but then your car would start without pushing the pedal all the way in that wouldnt give you a no start condition
Old Jan 18, 2006 | 05:45 AM
No2Pencil's Avatar
Default Re: (jdeemseerx)
the clutch isnt sliping, the cable was. i cant remember the name of the clutch , it was recomended by Noyan USA. the car never started without pushing the clutch, iv adjusted it untill the tranny wont go into gear, to where the gears go right in without clutch (car off).
Old Jan 20, 2006 | 06:16 AM
bagpipe goatee's Avatar
loosen the cable back to where it was and try it. how old is the clutch? how hard do you drive it? because when they start to break apart and go, they screw with adjustment a lot.
but, then again, the cable could just be fraying and stretching, too.
what i think happened (why it won't start) is that you put the cable so tight that the clutch pedal won't reach the floor, therefore not tripping the sensor saying you pushed in the clutch.
Old Jan 20, 2006 | 04:38 PM
vtechrex's Avatar
it could be the clutch fork, i dont know how common it is but it happened to one of my friends
Old Jan 22, 2006 | 10:23 AM
No2Pencil's Avatar
i looked over the whole clutch pedal and there are the two cylinoids… what I have going on is… the clylinoid on the bottom passes through a whole in the clutch pedal, and my top cylinoid doesn’t get pressed down... is the top one supposed to be pressed down? if so i fixed it... respond try'n to dick anything up
CarlosP11
Mar 25, 2011 10:57 AM
95legacy
Sep 24, 2007 09:55 AM
ej_vtec
Oct 29, 2006 03:33 PM
No2Pencil
Jan 22, 2006 11:35 AM
2jz240z
13
Aug 23, 2005 09:45 PM
