Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
Ignition switch?Main Relay? What is it?????????
Old Jan 16, 2006 | 03:49 AM
tgorman928's Avatar
Default Ignition switch?Main Relay? What is it?????????
I'm having a problem with my 1991 Acura Legend. First of all, when i put the key in to start it, nothing comes on in the panel area (engine lights, blickers,SRS, P-R-N-D-2-1 lights) but as soon as I turn it to start it, they all come on, and when I let go of the key after it starts, the car just dies and so does all the panel lights. than the radio will be the only thing to come on. I've gotten a few suggestions, ignition switch, main relay, but I can't seem to figure it out. HELP!!! when I hold it just right in a certain spot after I have turned it over, if I continue to hold the key in that certain position, I can drive the car like it was on it's own. But that 's hard to do, especially when you have to almost be slumped over to hold the key and try to steet with the other. PLEASE SOMEONE HELP ME, I HOPE I'VE GIVEN ENOUGH INFO.......
Old Jan 16, 2006 | 09:17 AM
C4wrx's Avatar
Default Re: Ignition switch?Main Relay? What is it????????? (tgorman928)
if the car starts , it is most likely the ignition switch.
Old Jan 16, 2006 | 04:48 PM
Kenso's Avatar
HT White Ops
Electrical portion of the ignition switch.
Old Jan 16, 2006 | 04:54 PM
b62pteg#2's Avatar
Default Re: Ignition switch?Main Relay? What is it????????? (C4wrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C4wrx &raquo;</TD></TR><TR><TD CLASS="quote">if the car starts , it is most likely the ignition switch. </TD></TR></TABLE>
I agree. In the past two months, I've put a new ignition switch in one Legend and two Integras (I'm a tech at Acura). And the problems are pretty much identical: radio will work, car will start then shutoff. And, if you hold it just right (it's how we get it into the garage so we don't have to push ), it's driveable.
Not exactly the images we use at work, but look at part #11. That's what you need. They aren't really difficult to install, either. Good luck
-- Kevin
Old Jan 21, 2006 | 05:31 AM
u n v kenny's Avatar
Default Re: Ignition switch?Main Relay? What is it????????? (b62pteg#2)
Part # 35130-SP0-305. Give a call to the number below, ask for Kenny.
The switch lists for $63.68. I'll let you have it for $50.94 plus tax. (Credit card only)
Old Feb 7, 2006 | 04:52 AM
Default Re: Ignition switch?Main Relay? What is it????????? (unvdis)
Thanks Jennifer.
Old Feb 7, 2006 | 04:31 PM
wade's Avatar
will that part number work for a 97 HX civic that needs an ignition switch?
Old Feb 17, 2006 | 04:46 AM
Default Re: Ignition switch?Main Relay? What is it????????? (wade)
Doubt it, but call Honda and ask them to check the part #.
Old Feb 23, 2006 | 10:07 PM
Mike K's Avatar
dude, i must have done 40 or 50 of those when i was an acura tech. lol, they ALWAYS go out.
that, and power window master switches on 91-95 legends. lol.
Rhdae86
Jul 29, 2011 05:44 PM
kevpple
Nov 14, 2010 04:05 PM
c0d0r
10
Feb 26, 2008 11:57 AM
messeduprex
Feb 8, 2006 10:17 PM
