electrical problem?
if the keys arnt in and the car is just sitting still and u press the break all the interior lights come on. then if u put the keys in and start the car it runs until u press the break or the gas then it dies and u cant start it for about 10 min then u can again wtf is the prob ?
hey this is the kid that posted this but im on my name now but no i looked for an old alarm but there isnt one in the can and i changed the main relay but it didnt no anything and i drove the car for like 3 weeks after i bought it and it worked fine then it just start having all kinds of **** going on ... but i dont know what it could b do u have any other ideas ??
the first symptom happened to my friend he put the wrong brake light bulb in one the lights and it was causing the cluster lights and all the dash lights to come on i would check your brake light bulbs first.. and then go to fuses as for the other car not starting deal start with the basics check fuel, spark, and timing
Sounds like a bad ground somewhere, possibly some corrosion. could also be in your brake light wire harness or bulb socket, make sure all are connected well and are not corroded.
