Rewiring Foglight Issue?
Old Jan 15, 2006 | 09:00 PM
the niz jiz's Avatar
Default Rewiring Foglight Issue?
I followed G2ic.com rewiring foglight tip...now my light turns off sometimes...and i think i smell burning wires but im not sure if its either the wire burning or me being paranoid about it....is there anything i need to be worried about..or it should be str8?
Old Jan 16, 2006 | 08:20 PM
Default Re: Rewiring Foglight Issue? (N.O.R.E)
no one?
Old Jan 16, 2006 | 10:24 PM
Sic_DA_Nine's Avatar
double check wiring...if it turned off..maybe the fuse is blown?
i did it when i had a g2...and it never gave out on me
Old Jan 16, 2006 | 10:51 PM
Backk InTheDA's Avatar
I hate everything
Default Re: Rewiring Foglight Issue? (97dC4)
Are these like fog lights on the headlight, or another set of fogs. I would just run it straight to a switch, and then ground it somewhere.
Old Jan 17, 2006 | 10:43 AM
Default Re: Rewiring Foglight Issue? (BuilttB18C5)
im guessing its the ones on the headlights.
Old Jan 17, 2006 | 01:00 PM
Robstunner4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97dC4 &raquo;</TD></TR><TR><TD CLASS="quote">double check wiring...if it turned off..maybe the fuse is blown?
i did it when i had a g2...and it never gave out on me</TD></TR></TABLE>
word, done it on 2 cars, works 100% of the time.
check ur wiring.
Old Jan 17, 2006 | 02:07 PM
Default Re: Rewiring Foglight Issue? (Robstunner4)
well it turns off because i think the wire is not on right....i tap the dash and it turns on...im just worried about if it'll short anything out....its some 30 jdm yellow h3 bulbs i bought with stock volt
Old Jan 18, 2006 | 12:19 PM
rewire it.....
what are u using to wire them together?
Old Jan 18, 2006 | 06:43 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Robstunner4 &raquo;</TD></TR><TR><TD CLASS="quote">rewire it.....
what are u using to wire them together?</TD></TR></TABLE>
i did what it said..i cut it 2inches from the switch and spliced it onto the defogger switch...so it would be the red/yellow wire
Old Jan 18, 2006 | 09:05 PM
did u use a crimp or a wire nut or........?
Old Jan 19, 2006 | 06:26 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Robstunner4 &raquo;</TD></TR><TR><TD CLASS="quote">did u use a crimp or a wire nut or........?</TD></TR></TABLE>
....or electrical tape??
envision
Dec 11, 2007 03:40 PM
USDMSiR
Jan 9, 2007 05:28 PM
.Slug
Oct 29, 2006 10:04 AM
i hate rice
11
Aug 22, 2006 05:26 PM
FBP Si 2000
Dec 23, 2003 05:16 PM
