Codes 41 and 12
Old Jan 15, 2006 | 08:46 PM
Dmc1's Avatar
Default Codes 41 and 12
what do these two codes meen?I get these when I pull the code on my 90 accord ex.I've had a check engine light for years.The car runs fine but it's a little hard on gas.Could it be the o2 sensor?
Modified by Dmc1 at 9:58 PM 1/15/2006
Old Jan 16, 2006 | 06:36 AM
JimBlake's Avatar
Default Re: Codes 41 and 12 (Dmc1)
12 = EGR lift valve.
41 = O2 sensor heater circuit.
Unplug the O2 sensor, measure resistance between the 2 same-color wires. Should be 10 to 40 ohms. If that's OK, then look for wiring problems in the car for that circuit. (Loose plug?)
My EGR hasn't screwed up, so ???
Old Jan 16, 2006 | 03:47 PM
Dmc1's Avatar
Default Re: Codes 41 and 12 (JimBlake)
Thanks man I'll test it and let you know
wing.jai
26
Sep 10, 2011 05:35 PM
S2KILLA
Jul 7, 2010 08:30 AM
tram1666
Dec 12, 2007 09:06 AM
SystemGSR
Jun 3, 2002 09:56 PM
