so whos used aircraft remover when polishing their wheels?
Old Jan 15, 2006 | 07:01 PM
.adam.'s Avatar
Default so whos used aircraft remover when polishing their wheels?
ive got some flat black slips and want to polish them. i was reading that if u just remove all the paint with aircraft remover they look like they are polished. would u still need to sand them and polish them after you used the aircraft remover? and another question... can you clear coat your wheels after you polish them so they last longer?
thanks a lot
adam
Old Jan 15, 2006 | 07:06 PM
C4st0r_Tr0y's Avatar
Official H-T Cake Maker
Default Re: so whos used aircraft remover when polishing their wheels? (civicskater)
Aircraft Paint Remover should work on removing the paint. but dont burn yourself. I think you may have to do some sanding/polishing after if you want the bling factor.
Old Jan 15, 2006 | 07:08 PM
-Gambit-'s Avatar
a friend of mine used it on his gt3's and they came out nice
Old Jan 15, 2006 | 07:11 PM
.adam.'s Avatar
so could you just use the aircraft remover and then use some polishing compound?
Old Jan 15, 2006 | 07:18 PM
-Gambit-'s Avatar
Default Re: (civicskater)
you are going to have to sand them down before using the polishing comp on them
Old Jan 15, 2006 | 07:28 PM
.adam.'s Avatar
o ok
thanks for the help
can you clear coat the wheels after using the polishing compound? im thinking no, but just wanted to make sure
o and does anyone have any pics
Old Jan 15, 2006 | 07:32 PM
LoSt is BlaCk's Avatar
where is that link for the DIY polishing?
Old Jan 15, 2006 | 07:39 PM
EJ1_203's Avatar
Default Re: so whos used aircraft remover when polishing their wheels? (-Gambit-)
i was thing bout doing the same .. i dont think u have 2 sand after the air craft iff u get it all off
Old Jan 15, 2006 | 07:43 PM
Chris.'s Avatar
Honda-Tech Order of Merit
Default Re: so whos used aircraft remover when polishing their wheels? (EJ1_203)
i used it on my mugens with some steel wool (2 grit) and it came off without any problems
https://honda-tech.com/zerothread?id=1259115
link for polishing wheels
Old Jan 15, 2006 | 07:44 PM
.adam.'s Avatar
has anyone actually done this that can give some insight? ill see if i can find some diys and post the links
Old Jan 15, 2006 | 07:48 PM
DUFFM4N's Avatar
Aircraft Remover, or Jasco Paint remover (aresol can)
after spraying it on the wheels let it sit for about 30min to give it enough time to eat through all the paint (this will save u time of using the steel wool to remove wuts left over)
after u clean all the paint off, sand with 600 grit and move up to 1000 or 1500 grit
to get the "bling" factor, use Mother's Mag Wheel Polish, rub it on with a towel (if its turning black, then its working)
be prepared to put in a full days work to do all 4 wheels
Old Jan 15, 2006 | 07:56 PM
.adam.'s Avatar
thanks a lot
Old Jan 15, 2006 | 08:03 PM
DUFFM4N's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicskater &raquo;</TD></TR><TR><TD CLASS="quote">thanks a lot
no problem...done this MANY of times on wheels that ive owned, for friends, girlfriend, and ppl that have paid me to do it...this is wut seems to work best for me
Old Jan 15, 2006 | 08:04 PM
Madspeed's Avatar
https://honda-tech.com/zerothread?id=1198647
Old Jan 15, 2006 | 08:05 PM
DUFFM4N's Avatar
Default Re: so whos used aircraft remover when polishing their wheels? (Madspeed)
^^ thats the stuff
Undercover_Skank's Avatar
Default Re: (DUFFM4N)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DUFFM4N &raquo;</TD></TR><TR><TD CLASS="quote">Aircraft Remover, or Jasco Paint remover (aresol can)
be prepared to put in a full days work to do all 4 wheels</TD></TR></TABLE>
thats what i did
Old Jan 15, 2006 | 08:08 PM
HamiltonRex's Avatar
Default Re: (Undercover_Skank)
I used some stuff on my valve cover.. It was goopy. Took 3 layers of stock/my paint off in about 5min. Then used some stripping pads on it after it bubbled.
Took it right down to bare alum.. looks oldschool now
Old Jan 15, 2006 | 08:31 PM
DUFFM4N's Avatar
Default Re: (HamiltonRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex &raquo;</TD></TR><TR><TD CLASS="quote">I used some stuff on my valve cover.. It was goopy. Took 3 layers of stock/my paint off in about 5min. Then used some stripping pads on it after it bubbled.
Took it right down to bare alum.. looks oldschool now </TD></TR></TABLE>
sounds like u used Jasco (the gel form)
i find the aresol cans easier and faster to use
Old Jan 15, 2006 | 09:00 PM
darkside's loreto's Avatar
i used aircraft remover...buthat was only the first step of a loooong process
94 accord typeR
Aug 2, 2014 06:49 PM
dth0ng69
Nov 8, 2009 11:43 AM
CeeJayy
Sep 18, 2007 06:26 AM
S2kGuy07
Honda S2000
14
Jun 12, 2007 12:34 PM
be18see1
Dec 13, 2006 08:52 AM
