2002 Civic Coupe with 2002 RSX Type-R Engine, Can it be done? or it's just a dream?
Old Mar 21, 2002 | 07:28 AM
Asild's Avatar
Default 2002 Civic Coupe with 2002 RSX Type-R Engine, Can it be done? or it's just a dream?
they both were K-series engine, is it possible to be done?
i realize the problem would be the wiring harness, but the engine mounting should be 'bolt on' right?
opinions please.!! thx.
Old Mar 21, 2002 | 09:26 AM
Trey's Avatar
25 Year Member
Default Re: 2002 Civic Coupe with 2002 RSX Type-R Engine, Can it be done? or it's just a dream? (Asild)
02 Si and 02 Integra Type-R engine will bolt in.....
No RSX Type-R
Old Mar 21, 2002 | 11:52 AM
SpooN Man's Avatar
Default Re: 2002 Civic Coupe with 2002 RSX Type-R Engine, Can it be done? or it's just a dream? (Trey)
I don't think that it is a bolt in affair. No one has done it yet. I would think that ps steering and ac would be a huge bitch. Just look at the differences between the 2002 civic and the RSX. The 2002 is the same layout as the 92-00 civic's. That's not to say with alot of cutting and welding and Most importantly A SHITLOAD OF MONEY
Old Mar 21, 2002 | 11:57 AM
Ausmith's Avatar
Default Re: 2002 Civic Coupe with 2002 RSX Type-R Engine, Can it be done? or it's just a dream? (SpooN Man)
Direct swap.
Old Mar 21, 2002 | 12:25 PM
SpooN Man's Avatar
Default Re: 2002 Civic Coupe with 2002 RSX Type-R Engine, Can it be done? or it's just a dream? (Ausmith)
bullshit no way it's direct
Old Mar 21, 2002 | 02:16 PM
Trey's Avatar
25 Year Member
Did you happen to notice I said 02 Si?
It has the base RSX 160hp K20 motor in it.
02 Type-R motor is a direct replacement........
So is the 02 CRV K24 motor.........
01-02 Civic coupe will not work.......
Old Mar 22, 2002 | 05:27 AM
SpooN Man's Avatar
Are you blind. He was talking about the 2002 coupe. Not the SI, I know that is a direct replacement
it's all good
By the way, nice clean design on your website.
[Modified by SpooN Man, 3:03 PM 3/22/2002]
Old Mar 22, 2002 | 03:43 PM
Asild's Avatar
ok, i'm confuse here!!! Can 2002 RSX Type-R engine be put into 2002 Civic coupe??? NOT the 2002 SI thx.
Old Mar 22, 2002 | 06:25 PM
brian g's Avatar
Default Re: No
It is not a direct bolt in. There are some differences in the way the mounts bolt to the framerails.
Last week we bought a 2001 RSX Type S complete engine changeover, a 2002 Civic Si and a 2001 Civic Sedan. The Type S motor is going to go in the Si and the Si motor will go into the '01 Sedan. A mount kit should be ready by July.
brian g
Old Mar 23, 2002 | 12:31 AM
GokuSSJ4's Avatar
Jeff from importbuilder said that he could do it !
Old Mar 23, 2002 | 10:44 AM
Trey's Avatar
25 Year Member
Default Re: No (brian g)
Currently, No you can't put the RSX motors in a 01-02 coupe since it's a completely different motot and the mounting locations are different.
If anyone can do it Brian G from http://www.hasprot.com can!!
Can't wait to see the "bolt-in" kit.
...and the 02 CRV 2.4L block in the Si
Old Mar 23, 2002 | 06:04 PM
elmo's Avatar
25 Year Member
Default Re: No (Trey)
It will work. However, you would have to change the 01+ Civic Coupe subframe to the 01+ RSX/CRV/Civic SI subframe along with the swap.
[Modified by elmo, 7:05 PM 3/23/2002]
Old Mar 23, 2002 | 07:48 PM
Turbo Laser's Avatar
Default Re: No (elmo)
Brian G has spoken...
Old Mar 23, 2002 | 08:35 PM
Kamin's Avatar
Default Re: No (ZCTURBO)
Brian rules.
i gotta come check out their facility sometime.
samnizzle
Honda Civic (2001 - 2005)
Feb 24, 2009 04:36 PM
JRsRoLLiN
Oct 14, 2002 05:24 PM
fastludeh22
May 29, 2002 08:46 AM
6SPD_EK
15
Nov 2, 2001 10:47 AM
