type r running lean
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16racer23 »</TD></TR><TR><TD CLASS="quote">i got a 98 type r, im using a stock gsr ecu, check engine comes on says system runnning lean. do i get a fuel pressure regulator?</TD></TR></TABLE>
I would get an P73 ITR ECU.
why are u running a gsr ecu? you would be better off running a stock ecu rather than fussing with a FPR. if you are actually running lean though I doubt it. only one way to find out for sure...
