4-inch ID flange K&N for Comptech Icebox plus tube?
Old Jan 14, 2006 | 06:01 PM
GRM Scott's Avatar
25 Year Member
Default 4-inch ID flange K&N for Comptech Icebox plus tube?
Well, cleaned my Comptech/Uni filter today using some diluted Purple Power as degreaser, and the poor bastard started to dissolve where the majority of the gunk was. Inner layer of foam is still intact, but the other blue layer is very gone in a couple of spots. Probably going to replace it with a K&N, and I know everyone recommends the RU-3130 or E-2427, but those are both 3.5-inch inner-diamater flanges, and unless I'm smoking crack the Comptech UNI filter's ID is 4 inches, as is the shaped plastic tube that connects the airbox to the Comptech short-ram tube.
Did a search on the K&N site and found this:
http://www.knfilters.com/searc...-2590
Should fit in the box and has a 4-inch flange to interface with the Comptech IceBox hose. What kind of setups are you guys using that allow a 3.5-inch ID flange?
Old Jan 15, 2006 | 04:20 PM
GRM Scott's Avatar
25 Year Member
Default Re: 4-inch ID flange K&N for Comptech Icebox plus tube? (GRM Scott)
Well, I guess it's good that nobody said "do a search!"
Nobody has info on how they got the 3.5-inch K&N filters to work on the comptech's 4-inch diameter? Are you omitting some part of the Icebox setup?
Old Jan 15, 2006 | 05:48 PM
D's Avatar
D
hey bitch... just go order the 4" ID K&N from autozone or any other local store... if it doesn't fit your needs... return it with the volvo and order the 3.5" ID.
per or anyone else down there have any DCOE 40's?
Old Jan 15, 2006 | 07:56 PM
GRM Scott's Avatar
25 Year Member
Default Re: 4-inch ID flange K&N for Comptech Icebox plus tube? (D)
Post *****. I'll see about DCOE40s.
Old Jan 15, 2006 | 08:14 PM
Todd00's Avatar
I said I don't want a title!
Can the Icebox take an OEM airfilter? If it can, you could do the RU-3130 conversion with an old stock filter.
Old Jan 15, 2006 | 08:15 PM
jetydosa's Avatar
25 Year Member
Im using a RU-3130 on a cutup stock filter's base, there was a thread many moons ago on how to cut the stock filter to allow the K&N to be clamped onto it.
It fits in the Icebox no prob, but now I am curious about the 4" one you posted...
Old Jan 15, 2006 | 08:25 PM
SwiftTypeR's Avatar
New User
the oem itr filter fits in the icebox. i have that in my vehicle right now. i also have the comptech foam filter...but i dont think its going to make much difference.
Old Jan 25, 2006 | 08:31 PM
GRM Scott's Avatar
25 Year Member
Default Re: (SwiftTypeR)
The 2590 finally showed up, the Comptech's nicely shaped plastic filter flange is ever so slightly larger than the inner diameter of the filter, but K&Ns are pretty flexible so with a little bit of prying-on help from a screwdriver it fit beautifully, snug even before the tightening of the hose clamp. It looks just like it did before but with a K&N instead of a UNI filter, no mods or tweaking needed. I'll take a pic if I remember to bring the camera back from the office, but if you're in the market for this one and you want to keep the nice funnel that connects your hose to the Icebox, this is a nice way to do just that.
Old Jan 26, 2006 | 05:38 AM
1GreyTeg's Avatar
Default Re: (GRM Scott)
Hey Scott, be sure to post up pics and or comparison shots. This topic will certainly pop up several times in the future and pics always help
Old Jan 26, 2006 | 05:39 PM
itgsr98's Avatar
Default Re: (1GreyTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GreyTeg &raquo;</TD></TR><TR><TD CLASS="quote">Hey Scott, be sure to post up pics and or comparison shots. This topic will certainly pop up several times in the future and pics always help </TD></TR></TABLE>Yes i second this. Good info for future ref. Thanks.
p0gi_b0i_integra
26
Apr 22, 2007 10:26 AM
Jt240
Sep 17, 2002 01:49 AM
BSQ
Apr 15, 2002 09:11 PM
