Climbing Idle Problem
Old Jan 14, 2006 | 10:35 AM
90AcuraIntegra04's Avatar
Default Climbing Idle Problem, 4k rpm idle!
Okay so i recently got a chipped ecu, the car idled good but was throwing a MAP sensor code. I was driving it around and it ran a little rough but was driveable. All of a sudden my idle got to 3k rpms, later on as i drove it got to 4k rpms! I had to drive home as low as 4k rpms. I went to a local junkyard and got the map sensor. I am not throwing any CEL light codes but my idle is still 4k! I start the car and it immediately goes to 4 or oever. I replaced the throttle body and map sensor so far and didn't fix it. I disconnected one vaccum line that hooks to the intake and it idled lower but like crap. Anyone have an idea? Thanks
Modified by 90AcuraIntegra04 at 12:40 PM 1/15/2006
Modified by 90AcuraIntegra04 at 12:41 PM 1/15/2006
Old Jan 15, 2006 | 11:42 AM
Default Re: Climbing Idle Problem, 4k rpm idle! (90AcuraIntegra04)
Please anyone? I cant drive my car like that.
Old Jan 15, 2006 | 02:19 PM
Ericfire66's Avatar
You may have a vacuum leak somewhere. I had the same problem a long time ago and its due to vacuum. Check all of your vacuum lines and any parts that have vacuum thats hooked up to it. Especially around the intake area. It sounds like you could also have something lose thats letting air into the manifold after the throttle body.
Old Jan 15, 2006 | 09:11 PM
Default Re: Climbing Idle Problem, 4k rpm idle! (Ericfire66)
I recently did a head gasket and had to take off the intake manifold, could i have not tightened it enough back onto the head therefore letting air threw? Thanks, Jim
Old Jan 15, 2006 | 09:18 PM
highmilehatch's Avatar
Did the car start acting up after you did the headgasket? Or after the "chipped ECU"?
Old Jan 15, 2006 | 09:24 PM
heres a doosy for you. I put the headgasket on and when i was installin a sensor, it shorted out my ecu so i ordered the chipped ecu. I started the car and it idled good but ran like crap. I got a CEL for the MAP senso. Replaced the sensor and it runs great but idles at over 4,000rpms. Thanks, Jim
Old Jan 15, 2006 | 09:25 PM
I also replaced the throttle body with another one and it didn't change a thing.
Old Jan 16, 2006 | 11:32 AM
Okay, i have changed out the throttle body (tps with it) iacv sensor and map sensor. I startefd my car and it idled low but reved up and down, i took it out for a dirve and afer gettin off the highway, i \hit the clutch and the idle went up to 6k and the brakes were hard, i could barley stop! I got home and shut it off, i started it up and it idled good for like 5 seconds then shot up to 6k again. Anyone have a idea? I plugged the wholes in my intake with my fingers before the 6k problem and it stopped my idle from bouncing. thanks, Jim
Old Jan 16, 2006 | 11:38 AM
gATOr65's Avatar
same thing happened to me. i would also like to know this. but more than likely it will prolly be a vacuum line. atleast that is what i have heard
Old Jan 16, 2006 | 11:40 AM
b_serious's Avatar
tried putting a stock ecu back in it?
Old Jan 16, 2006 | 11:46 AM
I dont have a stock ecu, mine fried. Im really starting to think thats it now, thanks.
greenzchatch
Jul 29, 2010 02:14 PM
I Like Hondas
Jun 11, 2006 05:35 PM
talley2191
Jan 31, 2006 07:13 PM
SoHov
Oct 28, 2005 10:16 AM
Prevail
Feb 26, 2003 05:57 AM
