password cf intake
Old Jan 14, 2006 | 09:22 AM
ithrowpoop's Avatar
Default password cf intake
i just received my password cf power chamber intake, nice stuff. only thing is it doesn't have the hose fitting on it to run a hose from the valve cover to the intake. i know running a breather filter on the vc isn't the greatest idea and i don't want to make a hole in the intake. what should i do?
Old Jan 14, 2006 | 09:51 AM
HYREV2NR's Avatar
Default Re: password cf intake (ithrowpoop)
Just put a small breather filter on the valve cover.
Old Jan 14, 2006 | 09:52 AM
Im_In_There's Avatar
add some NOS to it POOP!
Old Jan 14, 2006 | 10:31 AM
ithrowpoop's Avatar
Default Re: password cf intake (Im_In_There)
you know i got that 125 shot already
Old Jan 14, 2006 | 10:54 AM
Ed 341's Avatar
I was looking at these also. It looks to be a nice piece, any idea of gains? I have an AEM CAI right now, I'm not sure if you've driven an R with this but if you have can you provide insight on pros/cons of each?
Old Jan 14, 2006 | 11:05 AM
1GreyTeg's Avatar
CF password JDM bLiNgTaStIcNeSs?
ricer
Hows the motor coming along anyway Brian?
Old Jan 14, 2006 | 11:23 AM
ebelp's Avatar
Brian, I have a breather filter if you want it. PM me.
Old Jan 14, 2006 | 02:08 PM
ithrowpoop's Avatar
Default Re: password cf intake (ebelp)
thanks john, but i have one. i was really trying to find out if the was any way to run the hose to it.
Old Jan 14, 2006 | 04:46 PM
JjuuN R's Avatar
Default Re: password cf intake (1GreyTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GreyTeg &raquo;</TD></TR><TR><TD CLASS="quote">CF password JDM bLiNgTaStIcNeSs?</TD></TR></TABLE>
LOOOOL Grey
Old Jan 15, 2006 | 01:26 PM
Lo-Buck EF's Avatar
time for a catch can
Old Jan 15, 2006 | 02:09 PM
intekragsr's Avatar
Default Re: (Lo-Buck EF)
DO NOT put a breather on the valve cover unless you want your engine full of sludge and run like ****. Get a proper catch can setup.
Old Jan 15, 2006 | 02:14 PM
citrus3000psi's Avatar
Default Re: (intekragsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intekragsr &raquo;</TD></TR><TR><TD CLASS="quote">DO NOT put a breather on the valve cover unless you want your engine full of sludge and run like ****. Get a proper catch can setup. </TD></TR></TABLE>
Whats a proper catch can setup? Ive seen many catch can setups that still have the valve cover breather connected to the intake.
But still since no one has anwsered this guys question i will try. Your gonna need to connect the valve cover to another vac source. I would recommond that you just slash cut the exhaust and hook it up there. You wont have to worry about oil going through the intake this way.
Old Jan 15, 2006 | 02:47 PM
ithrowpoop's Avatar
Default Re: (citrus3000psi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lo-Buck EF &raquo;</TD></TR><TR><TD CLASS="quote">time for a catch can</TD></TR></TABLE> as far as a catch can, i have one set up between the pcv hoses.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by citrus3000psi &raquo;</TD></TR><TR><TD CLASS="quote">
what do you mean by slash cut the exhaust?
Modified by ithrowpoop at 4:08 PM 1/15/2006
Old Jan 15, 2006 | 02:59 PM
RTW DC2R's Avatar
is this the replica m00gen box? does the m00gen have the breather hose port? i ran a breather filter for awhile, never really noticed a difference good or bad :shrugs: you could probably drill a hole and get a fitting on there assuming the C/F is nice and thick.
Old Jan 15, 2006 | 03:07 PM
ithrowpoop's Avatar
Default Re: (RTW DC2R)
it is a j's whale ***** replica.
Old Jan 16, 2006 | 07:05 PM
ithrowpoop's Avatar
Default Re: (ithrowpoop)
have not called password yet, but i found out my options.
1. breather filter
2. t-tap pcv to catch can hose.
3. drill intake, insert fitting.
4. keep it stock.
undecided.
Old Jan 16, 2006 | 07:10 PM
DvD3's Avatar
B A N N E D
just run a line down to the bottom of the motor venting to atmosphere or run a catch can
Old Jan 16, 2006 | 07:12 PM
ithrowpoop's Avatar
Default Re: password cf intake (DvD3)
catch can already installed. between the pcv hoses.
Old Jan 17, 2006 | 02:19 PM
machgo5go's Avatar
How come their website show's hose fitting on chamber?
Old Jan 17, 2006 | 02:38 PM
aeon's Avatar
Default Re: password cf intake (machgo5go)
quoted from passwordjdm on team-integra.net
"as for those of you that are asking about the tube, we did not do the metal nipple for the time being but anyone that orders one now we can upon request supply you with the metal nipple and detalied instructions on how to drill the hole out for it. its very simple to do."
Old Jan 17, 2006 | 02:48 PM
Opie's Avatar
That's bullshit. to Password for that, that's very surprising coming from them. They should have held orders until they had restocked the fittings or gotten everything straight.
I would mail it back and ask them to do it, if they crack it or screw up the job it's on them.
Old Jan 17, 2006 | 02:50 PM
ithrowpoop's Avatar
Default Re: (Opie)
that is the best answer i have heard yet. will be calling password tomorrow. thanks for all the help.
Old Jan 17, 2006 | 02:52 PM
Erik95LS's Avatar
Default Re: password cf intake (aeon)
like the guy above me said. Ask them for the fitting and just drill a hole and install it.
Matty.'s Avatar
I :heart: my Carbing can.
Old Jan 17, 2006 | 03:26 PM
ithrowpoop's Avatar
Default Re: (gumtape_deathmatch)
i just got off the phone with password. the fitting is not INSTOCK. it will be in in about 2 weeks and will send me one then. there is a flaw in the design. the non-abs version is not missing it, but the abs version is.
for a nice intake.
for missing a pretty important piece.
