vtec turbo
wats up guys? i have a jdm b16 motor and i was planning on going turbo, but i hear that vtec and turbo don't go well together, i heard that they interfere with each other. i just wanted to get your opinions on this, shud i go with LS turbo? or try the turbo in my b16? give me some advice fellas
you could do a ls vtec or get low compression pistons for the b16
try this https://honda-tech.com/zerothread?id=1492596
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr2000 »</TD></TR><TR><TD CLASS="quote">its much better to have a vtec head it flow much better than a non vetc head, and i don't think there is any interference.but try fi forum</TD></TR></TABLE>
better flow isnt always the best.
the reason why people say that they wont work well together is because it is harder to tune a vtec engine with boost. they have to tune the overlap out, but other than that the react great to boost
Modified by projectTeG at 8:05 PM 1/14/2006
mmmm stupid myths... vtec motors love boost. boost just does not like lots of overlap wich stock cams do not have...
You do have to notch the vtec rockers in order for them not to interfere with the inducer on the compressor wheel. good luck
edit:spelling owns me
Modified by mmuller at 1:46 AM 1/15/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller »</TD></TR><TR><TD CLASS="quote">mmmm stupid miths... vtec motors love boost. boost just does not like lots of overlap wich stock cams do not have...
You do have to notch the vtec rockers in order for them not to interfere with the inducer on the compressor wheel. good luck</TD></TR></TABLE>
whats this notching your talking about?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC 1 point 8 B »</TD></TR><TR><TD CLASS="quote">if your going to boost your b16 i say rebuild your block with pistons and rods..</TD></TR></TABLE>
id say he would be ok...its all in the tune.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG »</TD></TR><TR><TD CLASS="quote">id say he would be ok...its all in the tune.</TD></TR></TABLE>
ok if he was to get bolt ons boosting his stock b16 whats the most psi can he push?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC 1 point 8 B »</TD></TR><TR><TD CLASS="quote">ok if he was to get bolt ons boosting his stock b16 whats the most psi can he push?</TD></TR></TABLE>
look at turbos as a whole as how much Hp. psi differ between turbo sizes...meaning different hp on similar psi.
most b-series engine are good for about 300whp....many have made more reliably. the engine is only as good as the tune
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20integrapower »</TD></TR><TR><TD CLASS="quote">here we go again with the psi thing...psi isnt universal..u needa find out wat set up he has first</TD></TR></TABLE>
ok this kid is in my high school.. the car is a 94 rs his set up is a jdm b16 i beleive it came from a 00 civic sir.... ok so now can someone tell me the most he can run on it...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC 1 point 8 B »</TD></TR><TR><TD CLASS="quote"> ok so now can someone tell me the most he can run on it...</TD></TR></TABLE>
My tuner is running 12psi on a stock B16. Its all in the tune.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC 1 point 8 B »</TD></TR><TR><TD CLASS="quote">ok this kid is in my high school.. the car is a 94 rs his set up is a jdm b16 i beleive it came from a 00 civic sir.... ok so now can someone tell me the most he can run on it...</TD></TR></TABLE>
the strength of the engine is not gauged by the amount of psi it can take...its the amount of power it can put out. again i will say 15 psi on a t25 is different from 15psi on a t3...get my point??
another thing they mean when they talk about "vtecs" not being good for turbo aps, is probably because of the high compression pistons those motors have. Its not the vtec, unless they really are talking about the tuning, and the overlap in it.
the reason people say they kinda battle each other is because your already in boost by the time your'e in VTEC but its still working and makng power,i think the B16 has the best sounding VTEC, and its sounds so much better when its spooling,high compression is an issue,and you cant run but soo much boost on a stock motor, but with a good setup and tune that will accomidate to make up for not being able to run a crap load of boost.i'd say between 7-11 lbs depending on your whole setup and parts
