Someone please help...No spark CYL2??
Old Jan 14, 2006 | 07:11 AM
swappedcx's Avatar
Default Someone please help...No spark CYL2??
WEll been posting and bumping threads and no one ever replies to any of my posts. Hopefully this time i can get somewhat of a answer. Last night i was trying to get my car running right. CYL 2 was not firing. Pulled the wires while the car was running for any other cyl and it changed RPM, and you could see it ark. Pull the plug for cyl 2 and it did nothing, you could hear it sparking but not near as much.
So this morning i replaced the plugs, wires, cap and rotor and still the same code (manufacturer controlled ignition or misfire) and still cyl 2 is dead. with no spark.
Old Jan 14, 2006 | 07:21 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Someone please help...No spark CYL2?? (swappedcx)
We have no idea what car or engine that you have.
Pull the wire for #2, insert a plug, start the car, and see if it is sparking.
If it is sparking, try a compression test.
Old Jan 14, 2006 | 08:27 AM
swappedcx's Avatar
Default Re: Someone please help...No spark CYL2?? (Dogginator)
97 JDM ls motor in a 97 civic CX
no, i have no spark to cyl 2. And everyone keeps telling me to plug in my CKF well i have been out there for hours looking, pulled the timing belt cover and there sure as hell is no plug for a ckf, no spare plug period.
Old Jan 14, 2006 | 08:34 AM
Dogginator's Avatar
Daisy... Daisy...
What ECU? Any CELs?
Old Jan 14, 2006 | 08:36 AM
swappedcx's Avatar
p75 USDM ls ecu (obd2)
3 codes
secondary 02 sensor (no cat)
manufacturer controlled ignition or misfire ( i checked before witht he paper clip method and this code was the CKF)
and TPS low voltage
Old Jan 14, 2006 | 08:39 AM
Dogginator's Avatar
Daisy... Daisy...
Was the harness ever cut? Perhaps the motor cam with a bad TPS and distributor.
Old Jan 14, 2006 | 08:43 AM
swappedcx's Avatar
its the harness out of my cx, only wires i cut were to extend the o2 sensors. The TPS is a new sensor, and the dizzy was not on the motor when i got the car. I got the dizzy from a local salvage yard. My motor and trans are all from a import shop. Warranty ran out trying to get it running right. The car has never left my garage yet.
Old Jan 14, 2006 | 09:01 AM
Dogginator's Avatar
Daisy... Daisy...
Download a Helm manual here:
http://www.hondahookup.com/manuals
The distributor could be bad.
Old Jan 14, 2006 | 09:04 AM
swappedcx's Avatar
I already have the chilton civic and integra manuals.
Would a OBD1 Ecu and jumper cure this since the obd 1 motors wont look for the secondary o2 sensor and ckf?
justinCO
Jun 5, 2008 08:19 PM
P@@RB@Y
Dec 1, 2005 04:11 PM
P@@RB@Y
Dec 1, 2005 03:00 PM
asubennett
Aug 21, 2005 09:54 PM
SiR Kid
Oct 10, 2002 07:49 AM
