....QUESTION ABOUT HAVING 2 RESONATORS......
Old Jan 13, 2006 | 10:52 PM
drevinder's Avatar
Default ....QUESTION ABOUT HAVING 2 RESONATORS......
serched but couldn't find anything...
setup
eg b18c1
stock exaust manifold
test pipe, 2 .25 piping (1 resonator )with magnaflow muffler
ran very nice
now
same setup
except i changed the b-pipe to hks with 2 resonator's jdm 4 into1 header with 2.5 collector and es oval muffler
seem's like it's running slower...
could having 2 resonator's on b-pipe be the problem ...????
or i there another set-up that would work better...
TIA
Old Jan 13, 2006 | 11:01 PM
SOHC4life 96's Avatar
Default Re: ....QUESTION ABOUT HAVING 2 RESONATORS...... (drevinder)
I'm betting the dual resonators is what's slowing you down.
Old Jan 14, 2006 | 01:45 AM
PINEAPPLE's Avatar
Which resonators are you using? Generic + hks mid pipe and resonator?
Old Jan 14, 2006 | 02:03 AM
drevinder's Avatar
Default Re: (PINEAPPLE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PINEAPPLE &raquo;</TD></TR><TR><TD CLASS="quote">Which resonators are you using? Generic + hks mid pipe and resonator? </TD></TR></TABLE>
there is 2 built in-to the hks mid pipe....
Old Jan 14, 2006 | 05:14 PM
drevinder's Avatar
Default Re: (drevinder)
i know there are alot more knowledgeable people here...
Old Jan 14, 2006 | 05:38 PM
97spooncivic's Avatar
its most likely is the resonators, but i wouldnt think you would be able to feel such a great difference
Old Jan 14, 2006 | 06:08 PM
riceburnerryan's Avatar
well if there are 2 built into that mid pipe, maybe you should sell it and get another one? because obviously it slowed you down and now your complaining about it ...
Old Jan 14, 2006 | 06:19 PM
hapexamendios 2.0's Avatar
R.I.P.
Default Re: (riceburnerryan)
it just doesnt sound as fast now
Old Jan 14, 2006 | 07:30 PM
drevinder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceburnerryan &raquo;</TD></TR><TR><TD CLASS="quote">well if there are 2 built into that mid pipe, maybe you should sell it and get another one? because obviously it slowed you down and now your complaining about it ... </TD></TR></TABLE>
what i'm asking is ....what is the disadvanage-advanage of having 2 resonator's (hks is not cheap brand) they's in there for a reason ...but why 2 resonators...
even with es oval...it's pretty loud..
Old Jan 14, 2006 | 08:15 PM
VN712's Avatar
I don't think you will feel a difference switch between the two. I doubt it's the exhaust. Maybe you are just use to the car???
Old Jan 14, 2006 | 08:19 PM
Redline96LX's Avatar
* B A N N E D *
Default Re: ....QUESTION ABOUT HAVING 2 RESONATORS...... (B20ZLS)
Slight possibility that the two resonators could end up at one point, resonating off the same frequency, which could affect noise, but the effect on exhaust gas pull would be negligable since this aint a F1 motor, its a street Legal civic.
Old Jan 14, 2006 | 09:30 PM
downeyballz's Avatar
changine the header and larger exhaust is messing up your a/f ratio. it you were to get it tuned it would make more power. that bigger exhaust pipe and header are also hurting your low end and thats probly what your noticing
Old Jan 14, 2006 | 09:33 PM
lv6l's Avatar
i remember i had this problem. i ask a honda-tech member and he told me that resenator are to silent noise and it does not effect your hp. i dont know if this help but just want to let you know.
drevinder's Avatar
Default Re: ....QUESTION ABOUT HAVING 2 RESONATORS...... (Redline96LX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline96LX &raquo;</TD></TR><TR><TD CLASS="quote">Slight possibility that the two resonators could end up at one point, resonating off the same frequency, which could affect noise, but the effect on exhaust gas pull would be negligable since this aint a F1 motor, its a street Legal civic.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by downeyballz &raquo;</TD></TR><TR><TD CLASS="quote">changine the header and larger exhaust is messing up your a/f ratio. it you were to get it tuned it would make more power. that bigger exhaust pipe and header are also hurting your low end and thats probly what your noticing</TD></TR></TABLE>
thanks guy's....now this is kind of response i was wanting....some thing that made sence....
Old Jan 14, 2006 | 09:44 PM
* B A N N E D *
If you get a good exhaust system (not like a 3" downpipe or something THAT huge) but better than stock, you'll increase HP a little. Its not "tuning" but reset the ECU anyway. Then your car will start, and itll "learn" that its more free flowing, and adjust itself a bit. Like when i put on my intake, had to reset the ECU so it would learn theres more air, so itd add more fuel to gimme the more power.
Having two resonators cant hurt the car, tho it may not be optimal.
Reset the ECU and get back to us. It may "feel" like less power, but might not. My car's brakes "feel" worse since I upgraded, but in reality they DO stop the car sooner.
MyEG6
Dec 14, 2008 06:18 PM
recon23
Oct 22, 2008 05:24 AM
CivSiClone_96
Sep 20, 2008 07:49 PM
ForceXVII
Oct 16, 2005 05:40 PM
10K2HVN
Nov 27, 2002 12:02 PM
