water in taillights
Old Jan 13, 2006 | 09:30 PM
92hatch420's Avatar
Default water in taillights
fuse blew to my brakelights so i was checkin it out and in the housing there was like an inch of water in it the far small bulb blew into pieces and the big brake/tail light one had water inside of the bulb and it was like blue i was checkin it out couldnt find where there might be a leak at-- holla back
Old Jan 13, 2006 | 09:37 PM
JDM-EJ1's Avatar
Default Re: water in taillights (92hatch420)
More than likely it's a bad seal in the tail light. You can either: Re-seal it, or buy a new tail light. More than likely, I would chose the latter on this one.
Old Jan 13, 2006 | 09:38 PM
200k mile sol's Avatar
pull the whole taillight out and check turn it till the water drips out. worse comes to worse just get some clean silicone and silicone them in no more leaks
Old Jan 13, 2006 | 10:21 PM
spoonhatchback2001's Avatar
Default Re: water in taillights (TurbodK20hatch)
just buy 2 new taillight gaskets per lens and then drill small holes at the bottom of the lights for drains and then put you lights back on
Old Jan 13, 2006 | 11:00 PM
simplegreenmachine's Avatar
i drilled a hole in the bottom of my tail light=less water, im too broke to get a new taillight
Old Jan 14, 2006 | 07:31 AM
singlestic's Avatar
I had the same problem with my tailights so I broke down and bought new ones and new gaskets. Spendy though. I can get them for around 80 bucks a piece oem new.
Old Jan 14, 2006 | 07:34 AM
92vx-t's Avatar
Default Re: water in taillights (Goldwing)
My boy had that same problem, he soaked them in a tub of hot *** water for like twenty minutes. Then he pulled them apart, not sure with what and re-sealed it.
liyan1430
Honda S2000
Apr 21, 2012 02:34 PM
Ya Digg
Dec 7, 2008 06:21 PM
byronl
Sep 5, 2005 07:36 PM
Ls InTeGrA RaCeR
Jun 4, 2005 03:27 AM
d8168055
Dec 6, 2001 07:52 PM
