Hit a curb.. bought some new stuff, had it aligned still cuts to the left hard
Old Jan 13, 2006 | 06:08 PM
standbackimapro's Avatar
Default Hit a curb.. bought some new stuff, had it aligned still cuts to the left hard
Ok well i recently hit a curb on the driver side pretty hard, i bought a new lower control arm and put it in, 2 new shocks and struts, and had it aligned, and now it cuts to the left harder than when i was driving it home after the hit
what else could i need to replace?
BTW: The whole driver side hit, front and back tires were flattend
i only replaced the lower control arm because the other one didnt look bent
Old Jan 13, 2006 | 08:02 PM
P_Adams's Avatar
Default Re: Hit a curb.. bought some new stuff, had it aligned still cuts to the left hard (standbackimapro)
Who did the alignment, and did they give you the print-out of the "Before" and "After" figures.
Somethings definitely wrong, and those values will tell me what.
Generally, uneven Camber values between the L & R Front and Rear wheels will cause a definite 'pull'. Look for either the left front wheel tilted out, or the right front wheel tilted in at the top.
I would certainly hope they did a 4wheel alignment.
Check that you don't have a brake caliper hanging up (Binds in the applied position)
P
Old Jan 13, 2006 | 10:12 PM
Honda-Master's Avatar
in many occasions i have seen the beams bent, when hitting curbs..have the ft + rear beams checked..altough if bent you cannot get alignment into specs they would be way off..,,,
Did people that do the alignmet say that it was in specs??
Initial_drift
Feb 13, 2008 02:17 PM
Zerophase
Suspension & Brakes
Aug 21, 2007 07:48 PM
srswarts3
May 9, 2006 02:30 PM
alex_s817
Apr 22, 2006 11:44 PM
tranquil
Oct 26, 2004 12:02 PM
