Wiring Question
Old Jan 13, 2006 | 05:59 PM
rollydc69's Avatar
Default Wiring Question
Got a question. If i want an OEM wiring like this on the pic. Where Im gonna connect the ground wire from the pressure switch?? Right now my VTEC and pressure switch is hardwired straight to the ECU.
Im gonna used a OBD1 GSR harness on my 1993 CIVIC CX on my next engine project.
Old Jan 13, 2006 | 06:08 PM
CRXified's Avatar
Default Re: Wiring Question (rollydc69)
i grounded mine on the silinoid housing, u can ground it anywheres, its a GROUND lol
Old Jan 13, 2006 | 06:36 PM
rollydc69's Avatar
Default Re: Wiring Question (CRXified)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXified &raquo;</TD></TR><TR><TD CLASS="quote">i grounded mine on the silinoid housing, u can ground it anywheres, its a GROUND lol</TD></TR></TABLE>
i know, but do i still need to ground it eventhough im using the 94 GSR engine harness?? GSR harness will plug and play to the passenger tower right?? im worrying about the 2 wires (vtec and switch) that im gonna connect to the tower going to the ECU like oem
Old Jan 13, 2006 | 06:43 PM
95DxSi-R2
Guest
Posts: n/a
do u have a vtec harness from the tower back to the pcm?
Old Jan 13, 2006 | 06:48 PM
CRXified's Avatar
Default Re: Wiring Question (95DxSi-R2)
i think, in the first post, he said it was a GSR engine harness going into the CX car, so no VTEC wiring in the car. u will have to run it to the ecu
Old Jan 13, 2006 | 06:49 PM
rollydc69's Avatar
what pcm??? you mean ecu, nope not right now but thats why im asking this question to get the OEM look like the one on the pic,, im gonna hookup 2 wires from the shock tower plugs to the ECU, how about the ground of the pressure switch?? it says on the pic only 2 wires(vtec and switch) right??
thanks for all your help, kinda new on this, im ready to swap a 95 gsr on my EG and i want this to be clean like OEMs
Old Jan 13, 2006 | 06:57 PM
95DxSi-R2
Guest
Posts: n/a
if u do it clean like u want to do. your going to have to get the pins that go into the connector by the shock tower with the weather proof rubber things. and the ecu pins, unravel? all the tape and convelant tubbing and tape it back up again. f@ck all that
Old Jan 13, 2006 | 07:04 PM
rollydc69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95DxSi-R2 &raquo;</TD></TR><TR><TD CLASS="quote">if u do it clean like u want to do. your going to have to get the pins that go into the connector by the shock tower with the weather proof rubber things. and the ecu pins, unravel? all the tape and convelant tubbing and tape it back up again. f@ck all that</TD></TR></TABLE>
I think is not that hard, its easier than taking off the dashboard and convert all the wiring to SI just to get the VTEC
Old Jan 13, 2006 | 07:07 PM
rollydc69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXified &raquo;</TD></TR><TR><TD CLASS="quote">i think, in the first post, he said it was a GSR engine harness going into the CX car, so no VTEC wiring in the car. u will have to run it to the ecu</TD></TR></TABLE>
that's correct SIR, i want to used the shock tower plug like it shows on the pic, but pics shows only 2 wires, 1 wire for VTEC and 1 wire for Switch, how about the ground for Pressure switch??
thanks
Old Jan 13, 2006 | 08:46 PM
95DxSi-R2
Guest
Posts: n/a
the ground wire t's off to the ground by the thermastate. the three/four wire ground
Old Jan 13, 2006 | 08:55 PM
rollydc69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95DxSi-R2 &raquo;</TD></TR><TR><TD CLASS="quote">the ground wire t's off to the ground by the thermastate. the three/four wire ground</TD></TR></TABLE>
ic, thanks, that's the answer Im looking for.
cbustuner
Engine Management and Tuning
Mar 21, 2009 06:44 PM
RedRevolver
Feb 9, 2009 08:57 AM
DraginTeg93
Feb 9, 2007 05:04 AM
ek9vboi2
Jun 24, 2005 07:44 PM
B_CRUZ!
May 6, 2002 12:00 PM
