Timing Belt skipped a tooth, how to get it back to TDC??
Car is a 91 Integra. I was removing the crank pulley and the belt slipped. How can I get it back to TDC??? Thanks for any info, Ryan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAVEDIGGER »</TD></TR><TR><TD CLASS="quote">it's kinda hard to explain but I can alighn the bottom timing mark on the crank but then the cam one's are a little off. Not really sure what to do??</TD></TR></TABLE> get 2 i think 5mm punches to keep the cams straight
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAVEDIGGER »</TD></TR><TR><TD CLASS="quote">where do the keeper pins or whatever go, I can't really see where they go and don't want to mess anything up.</TD></TR></TABLE>
they go in the cam caps on the cylinder 1 side of the engine. you have to align the hole on the cams.
ill try and get pics up tomm
This is what a friend of mine said to do,
don't even take the lower t-belt covers off. Take the vave cover and upper t belt covers off. Set the crank so the white mark lines up with the arrows on the lower t belt cover. Then set the cams at TDC....slide t belt on, rotate engine CCW 3 teeth so the t belt tensions, then tighten back up the tensioner
wk9k
Mar 13, 2012 05:45 PM
hitvtecgetloud09
Mar 21, 2004 05:27 PM
