need help with water in trunk.. 1996 civic hatch dx
pull out the carpet and check around the vents and seals in the back my hatch did the same thing and the vent on the drivers side was leaking some sealant ought to do the trick
They are $4 each side from the dealership or you can go to walmart and get 4 sheets of these for 33 cents each and make your own. I did this the other day and it worked like a charm.
http://knoxforum.myunite.net/unt?id=144
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris »</TD></TR><TR><TD CLASS="quote">My money is on the taillight gasket.</TD></TR></TABLE>
i took out the panel.. and when i touch the gasket i can feel a little pool of water sittin on the gasket.. do you think thats the problem? when the water goes through frmo the hatch and into the tail lights water gets caught?
I had same problem because I had my amps in my spare tire compartment and one day my system shut off, and I saw that they were all wet.
I took everything out of the back of my hatch and stuck a construction flood light underneath my car. When you look into your hatch you will be able to see cracks/holes/etc. because of where the light is coming through. THen from there you can use silicone/cocking/or w/e u want to seal up all the cracks and what not.
GL, worked for me
GL, worked for me
ill take a pic of my hatch tonight.. i also need some help on fixing the small rust build up.. (never did this type of body work before so yea..) i need someone to lead me into a good direction lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by student_n1 »</TD></TR><TR><TD CLASS="quote">yups me to check those little vents in the back...i just got some silicone and it fixed the problem </TD></TR></TABLE>
what vents???????????????? someone tell me?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pinoyboiwonder »</TD></TR><TR><TD CLASS="quote">
what vents???????????????? someone tell me?</TD></TR></TABLE>
when you remove the carpet from the trunk you will see something in the bottom left corner he is talking about that vent. its the molded carpet on the side of it like by the rear shock tower
Here is the update..
I changed both my left and right tailight gaskets..
**Here is the problem.. My right tailight doesnt leak any more (right meaning when lookin at the back not from front).. <u>Now there is only water leaking from the left side.. i dont know if its the gasket.. any one can help me?? im going to buy some kmart foam thing and take out the new gasket from the left side and make it thicker and a lil longer. if thatsn ot the case can anyone point me in the right direction?? (BOTH GASKETS ARE BRAND NEW!)
My 95 civic ex coupe leaks water into the rear floorboards when it rains and the car is parked nose uphill(but not when parked nose downhill). Are there hoses that drain from the sunroof to the underside of the car? If so, how do I access or unplug the hoses? If not, what's the solution?
my car does the same thing and it is a coupe. i haven't had it replaced yet but i was told to have the rubber foam seal around where the trunk closes, but i don't know if it is similar for a hatch.
well.. i dont wanna remove my whole rear panel.. kinda lazy.. its not the tail light.. i think its one of the plastic protecter thing for the tail light spike thing to go into..
EL Vap133
Jan 5, 2006 07:03 AM
SPORT INJECTION
47
Sep 24, 2004 04:10 PM
