AJ PwR's dynoplot
Old Mar 20, 2002 | 07:17 PM
Saga's Avatar
Default AJ PwR's dynoplot
Here's the setup: (when it was still here )
B18C Type R motor
Spoon group A cams
Spoon cam gears
Spoon valvetrain
Spoon 2p head gasket
Spoon 4-2-1 header
Spoon plug wires w/ground
Spoon test pipe
Spoon rocker arms
Spoon oil pump
Spoon iridium spark plugs
Amuse R1 Titan catback exhaust (50.8mm OD)
AJR custom Intake box
AJR titanium retainer
AJR 70-62mm throttle body
AJR P&P head/manifold
AJR Pistons CR 12.2:1
AJR Full balanced
AJR reprogrammed ECU (OBD2) vtec 5900 rev 9500
Blitz SUS filter
stock injectors (balanced) / stock FPR / stock ignition system
CTR crank pulley
[Modified by Saga, 8:21 PM 3/20/2002]
Old Mar 20, 2002 | 07:19 PM
B2FiNiTY's Avatar
Default Re: AJ PwR's dynoplot (Saga)
Very impressive. B18C5 motor right?
Old Mar 20, 2002 | 07:20 PM
Saga's Avatar
Default Re: AJ PwR's dynoplot (B2FiNiTY)
Yes indeed.
Old Mar 20, 2002 | 07:23 PM
B2FiNiTY's Avatar
Lot's of dips...
Old Mar 20, 2002 | 07:24 PM
Rob :190:'s Avatar
Default Re: AJ PwR's dynoplot (fuzznuts)
i guess spoon stuff does work
Old Mar 20, 2002 | 07:28 PM
SMSP's Avatar
Lot's of dips...
Changing the smoothing factor would make it look "nicer".
Nice graph, I'm sure it's a blast to drive.
Old Mar 20, 2002 | 07:31 PM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
Default Re: AJ PwR's dynoplot (Rob1035)
Spoon group A cams...are those the "sports" cams that everyone can buy, or the "race" cams that only a few can buy?
Old Mar 20, 2002 | 07:33 PM
Saga's Avatar
Default Re: AJ PwR's dynoplot (Ross)
They are indeed the race version
Old Mar 20, 2002 | 07:34 PM
Reid's Avatar
Global Moderator
If anyone can get me Spoon Group A cams, please email me. I've been looking for them for a while.
[Modified by Reid, 6:42 PM 3/20/2002]
Old Mar 20, 2002 | 07:49 PM
itr0045's Avatar
Default Re: AJ PwR's dynoplot (Reid)
Look at the VTEC spike. Yummy!!! Bet that breaks the tires loose as soon as you hit 5800.
Oops maybe lower than 5800, more like 5 grand.
[Modified by itr0045, 4:50 AM 3/21/2002]
Old Mar 20, 2002 | 07:51 PM
SMSP's Avatar
How do these compare compare to the Toda Cs for lift, duration and ramp rates?
Old Mar 20, 2002 | 08:14 PM
Unlimited's Avatar
New User
xtrafastcivic's Avatar
Default Re: AJ PwR's dynoplot (SMSP)
AJ racing told me about these cams and they said they might get some of them and might sell a pair to me but i never heard from them stuff like that. but now i see where one pair went
if i had gotten a pair it would have been cool to say yeah they are spoon i guess just a strong pair of spoon sport cams
when it was still here ???????
[Modified by XtraFastCRX, 9:15 PM 3/20/2002]
Old Mar 20, 2002 | 08:41 PM
RagingAngel's Avatar
Default Re: AJ PwR's dynoplot (XtraFastCRX)
Drinking and Driving not only kills people...but kills beloved machines....
and for the record..it wasn't Ben who was drinking....so I'll let you guys figure out the rest.....
behind the wheel.....
Old Mar 20, 2002 | 08:44 PM
AllMotorITR's Avatar
New User
Default Re: AJ PwR's dynoplot (RagingAngel)
How do they compare to Toda Cs?
Old Mar 20, 2002 | 08:49 PM
garagespecial
Guest
Posts: n/a
ay an jay racin'
Old Mar 20, 2002 | 08:59 PM
Unlimited's Avatar
New User
Default Re: AJ PwR's dynoplot (garagespecial)
ay an jay racin'
ay an jay racin'
foe sheezy
Old Mar 20, 2002 | 11:23 PM
AJ PwR's Avatar
The regular version of Spoon cams with the identical setup is about 8-10whp less but the torque is pretty much the same which really suprised me. Also, with the reg. Spoon cams theres a dip before vtec x-over.
Old Mar 20, 2002 | 11:25 PM
AJ PwR's Avatar
The specs are IN 300 EX 288 total lift 12
Old Mar 21, 2002 | 03:12 AM
hybrider's Avatar
Default Re: AJ PwR's dynoplot (AJ PwR)
sweet
Old Mar 21, 2002 | 03:39 AM
done's Avatar
Default Re: AJ PwR's dynoplot (hybrider93)
wow thats an expensive motor , very impressive!!
Old Mar 21, 2002 | 11:57 AM
AJ PwR's Avatar
Default Re: AJ PwR's dynoplot (Jordo)
I am trying to fix the dips so I might plan to run H22 injectors and I have the MDI Direct fire installed and the car felt more smoother power.
I think this year I will be able to make it pass 210whp.
Old Mar 21, 2002 | 12:09 PM
Big Phat R's Avatar
Are you sure it's only 50.8 OD?? Seems pretty small - maybe 60.8 mm?? hmm?
Old Mar 21, 2002 | 12:14 PM
TypeR0207's Avatar
Default Re: AJ PwR's dynoplot (BPR)
Looks like it is a dawg before the VTEC x-over, and a brute up top!
Have you tried to smooth out the low end???
If you are running stock 240's, you are probably fuel starved ..... any AF ratio data?? Look how drastically it falls off at the top end ....
[Modified by TypeR0207, 4:15 PM 3/21/2002]
Old Mar 21, 2002 | 12:16 PM
Wai's Avatar
Wai
ProFunction/GT Motoring
If that exhaust is the same one as I thought, then that exhaust is straight out. And I mean STRAIGHT OUT. It doesn't go around the gas tank. It goes underneath it instead. So it's basically a straight pipe (with no resonator) from the cat/test pipe all the way to the muffler.
With that kind of layout, the flow is good enough so it doesn't need a big diameter pipe.
[Modified by Wai, 1:17 PM 3/21/2002]
