Clutch Chatter and Flywheel Chatter?
Old Jan 13, 2006 | 08:40 AM
migs's Avatar
Default Clutch Chatter and Flywheel Chatter?
Are these chatters RPM specific? What Im hearing is between 2200-2500. and goes away after that.
Old Jan 13, 2006 | 09:11 AM
Eva01's Avatar
Default Re: Clutch Chatter and Flywheel Chatter? (migs)
Is this after engagement? I understood clutch chatter as occuring when letting out the clutch and it's engaging with the flywheel. Not happening afterwards.
Old Jan 13, 2006 | 09:19 AM
migs's Avatar
Default Re: Clutch Chatter and Flywheel Chatter? (Eva01)
Happens in gear.
Old Jan 13, 2006 | 09:33 AM
splitime's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by migs &raquo;</TD></TR><TR><TD CLASS="quote">Happens in gear. </TD></TR></TABLE>
Shouldn't chatter once in gear... ie: you are in gear and accelerating.
Chatter tends to be an engagement time thing.
You might have something else going on
Old Jan 13, 2006 | 09:46 AM
92TypeR's Avatar
FSAE
Default Re: Clutch Chatter and Flywheel Chatter? (splitime)
The term clutch chatter is given to the resonance of the rotating assembly on the flywheel and clutch. This only occurs during idle, as engine harmonics are dampened by the transmission once in gear, and acceleration forces cancel any resonance frequencies if you are revving in nuetral.
There are exceptions to the above. Key RPM's create standing waves on parts othe drivetrain and it is possible to hear these harmonics while driving, usually at a low RPM, which could be what you are experiencing. Does this frequently happen in a higher gear while cruising, ie: 4th or 5th.
Old Jan 13, 2006 | 02:19 PM
migs's Avatar
Default Re: Clutch Chatter and Flywheel Chatter? (92TypeR)
http://www.we-todd-did-racing....5NTQx
Thats a video of when it happens and how the it sounds like.
Old Jan 13, 2006 | 02:29 PM
RTW DC2R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR &raquo;</TD></TR><TR><TD CLASS="quote">The term clutch chatter is given to the resonance of the rotating assembly on the flywheel and clutch. This only occurs during idle, as engine harmonics are dampened by the transmission once in gear, and acceleration forces cancel any resonance frequencies if you are revving in nuetral.
There are exceptions to the above. Key RPM's create standing waves on parts othe drivetrain and it is possible to hear these harmonics while driving, usually at a low RPM, which could be what you are experiencing. Does this frequently happen in a higher gear while cruising, ie: 4th or 5th.</TD></TR></TABLE>
so whats the noise I used to get all the time with my old ceramic 6 puck unsprung clutch disk and CM flywheel when releasing and depressing the clutch pedal and engaging first gear?
Old Jan 13, 2006 | 03:55 PM
92TypeR's Avatar
FSAE
Default Re: Clutch Chatter and Flywheel Chatter? (RTW DC2R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R &raquo;</TD></TR><TR><TD CLASS="quote">so whats the noise I used to get all the time with my old ceramic 6 puck unsprung clutch disk and CM flywheel when releasing and depressing the clutch pedal and engaging first gear? </TD></TR></TABLE>
I couldn't guess w/o hearing it. I can get a video of our Supra idling, the clutch chatter is loud enough to hear from a block away. It could just be the way that particular clutch sounds when engaging...
Old Jan 13, 2006 | 04:09 PM
RTW DC2R's Avatar
hmm ok I was always under the impression I had clutch chatter and that it occurred when engaging and disengaging the clutch. but my clutch was garbage so maybe it was related to that instead .
HS2G
Aug 22, 2004 08:45 PM
preluder
Jun 24, 2003 07:00 AM
Seann
Jan 31, 2003 02:48 AM
OneThirtyEight
Jul 5, 2001 08:18 AM
