griniding/scraping noise in 1st/2nd/3rd gear....
Old Jan 13, 2006 | 08:14 AM
TiredToyotaDriver
Guest
Posts: n/a
Default griniding/scraping noise in 1st/2nd/3rd gear....
what up fellas... My dad seems to think I have a bad bearing in my tranny... when the clutch pedal is RELEASED, i get a sort of knocking scraping grinding kinda noise... stops as soon as the clutch is engaged... also, when I'm driving regularly... from about 2.5-3k on in 1st/2nd/3rd gear it starts doing the same noise... with more scraping... pretty sure it's my tranny... any other ideas??
Old Jan 13, 2006 | 08:20 AM
vietjdmboi's Avatar
maybe the throwout bearing??
Old Jan 13, 2006 | 08:26 AM
TiredToyotaDriver
Guest
Posts: n/a
Default Re: (vietjdmboi)
possible... i just did the clutch/pp/bearings about 6 months ago... all OEM type-r... so it shouldnt be the throw out... im pretty sure its a problem inside the tranny...
and no, it has nothing to do with suspension/wheels/tires
Old Jan 13, 2006 | 08:59 AM
IN VTEC's Avatar
Default Re: griniding/scraping noise in 1st/2nd/3rd gear.... (TiredToyotaDriver)
A grinding and knocking noise might suggest that a bearing is significantly damaged. A slight grinding/chafing noise usually indicates that there's a moderate amount of wear, but otherwise still in one piece.
If it's making the noise while the clutch is engaged and not making the noise when the clutch is disengaged, then it's probably a bearing inside of the transmission. It could be any one or a combination of the bearings inside the transmission.
All of the transmissions I've seen with worn diff, housing, and/or shaft bearings usually have other wear issues (ie: shift forks, synchro sleeves, etc.) I recommend at least having a look at that stuff too.
Old Jan 13, 2006 | 06:08 PM
TiredToyotaDriver
Guest
Posts: n/a
Default Re: griniding/scraping noise in 1st/2nd/3rd gear.... (IN VTEC)
i'll prob get a whole new tranny... it makes the noise when the pedal is released... and when the car is actually moving in gear, it is a bit more severe... clutch in, no noise...
Old Jan 13, 2006 | 07:28 PM
watsvtecEK's Avatar
mine dose the same thing, but only when i am in gear, and i let of the gas. but when im on it, it dosnt do it.
Old Jan 13, 2006 | 07:44 PM
grndcont's Avatar
just replace the throw-out bearing, and use the one that is oem for that tranny. if the tranny is'nt a type r, dont put a r one in there. it wont make you faster.
Old Jan 13, 2006 | 10:04 PM
TiredToyotaDriver
Guest
Posts: n/a
Default Re: (grndcont)
i used all R parts because the PP and clutch was R..... **** happens, I'll try the throw-out bearing... if it isnt that, It looks like im getting a a jdm LSD tranny : D
Old Jan 13, 2006 | 10:34 PM
TheNosR's Avatar
Default Re: (TiredToyotaDriver)
its not the bearings its the sleeve not meshing with the synchro
Old Jan 14, 2006 | 08:04 AM
TiredToyotaDriver
Guest
Posts: n/a
Default Re: (h22special)
hrmm... is this a kinda thing i can fix or do i need a new tranny?? keep in mind I want to make it as reliable as possible.. and its gunna be 300ish hp... im thinking about getting an aftermarket LSD put in mine, maybe rebuild... or get an OEM lsd...
any other comments on what it could be, how to fix it, etc .?
Old Jan 14, 2006 | 08:26 AM
Dogginator's Avatar
Daisy... Daisy...
This point wasn't clear; does this grinding occur with the car in neutral?
Old Jan 14, 2006 | 07:26 PM
TiredToyotaDriver
Guest
Posts: n/a
Default Re: griniding/scraping noise in 1st/2nd/3rd gear.... (Dogginator)
car in neutral, clutch pedal out= knocking/grinding/chafing noise
car in gear, clutch out (moving)= more severe scraping
clutch pedal in=no noise
HondaLuv3r4Life
Transmission & Drivetrain
Dec 11, 2013 09:24 AM
OneFire
Aug 7, 2009 04:24 PM
carsaregood
May 11, 2006 11:14 AM
CPR
Dec 14, 2005 10:26 PM
Pinhead
Feb 4, 2002 12:37 PM
