si tranny to non-si engine
Old Jan 13, 2006 | 07:46 AM
4drslow's Avatar
Default si tranny to non-si engine
im looking at putting an si tranny in my non-si civic. it has a D15 in it and the tranny is for a D16.....will this work?
Old Jan 13, 2006 | 08:17 AM
iamdoughnut's Avatar
Default Re: si tranny to non-si engine (4drslow)
I don't think it will work. According to helms there are two types: S40 and S4C. The S40 is the most common transmission for the d-series. In fact, only the 2 door coupes have the S4C tranny.
When you look at the diagrams for removal of the transmission, the D16Y5 and D16y8 motors have a different bottom mount than the D16y7. Whereas the Y7 engine has one large bracket as the engine stiffiner, the Y8 and Y5 have two smaller brackets.
Anyway, I'm talking in theory, and aside from what I mentioned above, there is still a possibility it will work, I just have no firsthand experience.
Old Jan 13, 2006 | 08:18 AM
kyden's Avatar
it'll work.. you're talking about EG's, correct?
and to the above poster.. what? all the d series on EK's have the same mount configuration.
Old Jan 13, 2006 | 08:22 AM
blkhatch92's Avatar
i have a 92 hatch with d15b7 and z6 tranny . . .itll work, direct bolt up, easy as pie.
Old Jan 13, 2006 | 08:30 AM
4drslow's Avatar
Default Re: (blkhatch92)
im not real sure on the year of the tranny though. if it is pre 92 will it still work? it came out of a civic hatch si but im not sure on the year cause its currently in a 90 crx si
Old Jan 13, 2006 | 08:32 AM
skunk2eg's Avatar
Default Re: (4drslow)
well, is it cable or hydro? if its hydro, then yes it will bolt right up.
Old Jan 13, 2006 | 08:33 AM
black_EM1's Avatar
Community Builder
Community Influencer
Default Re: si tranny to non-si engine (iamdoughnut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iamdoughnut &raquo;</TD></TR><TR><TD CLASS="quote">I don't think it will work. According to helms there are two types: S40 and S4C. The S40 is the most common transmission for the d-series. In fact, only the 2 door coupes have the S4C tranny.
Anyway, I'm talking in theory, and aside from what I mentioned above, there is still a possibility it will work, I just have no firsthand experience. </TD></TR></TABLE>
S4C is the code for the 99-00 Si B16A tranny, isn't it?
Old Jan 13, 2006 | 08:48 AM
4drslow's Avatar
Default Re: si tranny to non-si engine (black_dohc)
i know its not all that new....its pre 96. i'll make sure its hydro. thanks for the help. were most of the si trannys hydro or did it vary?
Old Jan 13, 2006 | 11:56 AM
blkhatch92's Avatar
92+ are hydro 91 and below are cable
arrocha87
Jan 8, 2009 06:03 PM
dfoxengr
Welding / Fabrication
Dec 20, 2006 05:52 AM
no_one_
Nov 10, 2004 06:17 AM
niftyEJ6
Aug 20, 2004 08:05 PM
hybridcrx
Feb 28, 2002 04:38 PM
