1995 Honda Accord Speedometer problem.
My '95 Accord appears to have an intermittent issue with the speedometer. It'll be working and then suddenly it'll just drop to 19mph and stay there. Does anyone know what this could be?? Cable? Sensor? I've only had the car for a short while and this is the first Honda I've ever driven so I'm not quite sure where to start. Thanks!
If you had the "Service Engine" lamp coming on as well, I'd suspect the VSS (Vehicle Speed Sensor). Without any additional symptoms, it points more directly at the Speedometer itself.
Does it do it after any particular event; ie: hit a bump, stop suddenly. ETC.?
P
P
i had this exactly same problem except after a while it became WAY worse. one minute itd register 0 and then the next id be going around 180. i bought a new speed sensor and it didnt fix it. i ended up having to install a new speedometer. its not much trouble, get a haynes manual and its a breeze. same goes for the speed sensor. if you end up finding out it sthe speed sensor i have one ill sale you for cheap.
You're correct to suspect the Cluster/connection first.
When the VSS decides to take a powder, it will set a "Service Engine" Lamp, a DTC will be set and available to scan and it can effect no only the engine performance but the Transmission as well.
You're seeing none of that.
P
P
I have an 95 accord ex and my speedometer goes up and down then just stops after i drive for a while.It allso stalls when i peass the gas,the check engine light goes on and off . I can fix most things on the car myself but i cant find out whats wrong i have taken the car to a few shops but they seem lost themselves if any one has any idea what this is i would love to know thanks.
Does anyone know if the sensor gear (under the VSS) will spin with the front wheels off the ground and someone spinning the tire?
I'm trying to figure out why my new (JDM used) VSS is cutting in and out
P
P
The VSS is geared to the transmission output shaft. If the output shaft is spinning, the gear will spin regardless of whether or not the wheels happen to be on the ground.
mdjobadze
Jun 20, 2013 08:47 PM
1995, 20, 95, accord, honda, install, installation, intermittent, manual, problems, sensor, speed, speedometer, symptom, working
