time to replace spark plugs and wires?
Old Jan 13, 2006 | 12:58 AM
amej8's Avatar
Default time to replace spark plugs and wires?
my engine seems to be bogging. more specifically, when im driving, and accelerating at rpms below 4000, i can randomly feel the engine kick in harder. perhaps the engine is misfiring? im assuming i should change my spark plugs and wires. plugs and wires have never been changed as far as i know and im @ 162k miles. TB, IM, fuel injectors, etc. are all good n clean if that makes any diff.
also, whats a good website for oem spark plugs and wires? my engines completely stock so no use in getting high performance parts...
Old Jan 13, 2006 | 05:20 AM
SicilianSpeed42's Avatar
Default Re: time to replace spark plugs and wires? (amej8)
go to autozone or advance auto and do a complete tune up. cap/rotor/plugs/wires air filter if it hasnt been done in a while, maybe even fuel filter. if that doesnt fix your problem, try testing your tps.
Old Jan 13, 2006 | 05:41 AM
AutoXer's Avatar
Default Re: time to replace spark plugs and wires? (SicilianSpeed42)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SicilianSpeed42 &raquo;</TD></TR><TR><TD CLASS="quote">go to autozone or advance auto and do a complete tune up. cap/rotor/plugs/wires air filter .</TD></TR></TABLE>
Do not use Autozone ignition components, they suck. I've gotten wires from there that don't even fit, and the cap I got leaked and left me stranded on a rainy day.
Do you need to replace the wires? Are they damaged / cracked? I've seen OEM ones last the life of some civics. I would check the plugs / cap / rotor and see if it's time to replace them; and if you can't remember last time it was done, I would say it's a good time.
If that doesn't help at all, then start looking harder.
Old Jan 13, 2006 | 07:37 AM
Default Re: time to replace spark plugs and wires? (AutoXer)
yeah, thats a good point. I only buy plugs at advance. the rest of the stuff youd be better off getting oem.
Mlo93
Dec 21, 2015 11:33 AM
buymesomedunks
Jul 26, 2013 05:55 PM
Tuesdaynightfever
May 4, 2008 10:01 AM
AGB5901
Jan 20, 2004 03:20 PM
silveraccord01
May 6, 2003 09:03 PM
