civic to integra cluster wiring help
Old Jan 12, 2006 | 10:24 PM
lsismore's Avatar
Default civic to integra cluster wiring help
Anyone that can help me to figure out which wires go to which to make the cluster work would be greatly apprciated.
Old Jan 12, 2006 | 10:46 PM
B-SerioUs EGg's Avatar
B A N N E D
Default Re: civic to integra cluster wiring help (lsismore)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
i got the wiring for the cluster if any ever needs it
teg's blue left side plug (13 pins)
1. blu tach signal
2. grn/org check engine indicator
3. yel/red oil pressure switch
4. NOT USED NOT USED
5. wht/blu charge indicator
6. NOT USED NOT USED
7. yel/grn coolant temp
8. blk ground
9. red/blu cruise (if you have cruise)
10. yel hot
11. NOT USED NOT USED
12. pink maintenance (not used)
13. NOT USED NOT USED
teg's right side blue plug (16 pins)
1. grn/red e.brake signal
2. red/grn high beam
3. grn/yel right turn
4. grn/blu left turn
5. NOT USED NOT USED
6. blk/yel power
7. red/blk power
8. red power
9. blu/red abs (not used)
10. grn trunk switch
11. org vehicle speed sensor
12. NOT USED NOT USED
13. blu/wht low fuel (not used, cant be used w/ out integra gastank and sensor)
14. yel/wht fuel gauge
15. lt grn/red door switch (not used, can be used w/ extra wiring to the doorpins)
16. red/blu seat belt
civic's left side grey plug (12 pins)
1. yel/wht fuel gauge
2. yel/blu vehicle speed sensor
5. wht/blu charge
6. yel/red oil pressure switch
7. NOT USED NOT USED
8. blu tach signal
9. NOT USED NOT USED
10. blk/yel power
11. red/blk power
12. red power
civic's right side grey plug (10 pins)
1. red/grn high beam indicator
2. grn/red e brake signal
5. grn/org check engine indicator
6. blk ground
8. yel hot
9. grn trunk switch
10. blu/wht seat belt
match the wire colors and solder and tape the connnections.. make a custom housing for the dash as the cluster doesnt fit perfect can it can be made to look nice.
i just got done doing this with gsr cluster this will help you allot. </TD></TR></TABLE>
Old Jan 13, 2006 | 01:14 AM
BlueIntegraBoy's Avatar
Look at the link in my signature
9sihatch3
Sep 22, 2005 08:18 PM
dizzyroc88
14
Feb 29, 2004 11:44 AM
wacllp
Feb 27, 2003 09:06 AM
The G2 Racer
Oct 18, 2002 02:38 PM
DB8
Jun 10, 2002 07:53 PM
