Review: Jeff's Werkstatt Prime and Acrylic Jett
Old Jan 12, 2006 | 09:39 PM
GoobDetailer's Avatar
Default Review: Jeff's Werkstatt Prime and Acrylic Jett
I ordered this tuesday night (probably around 7 pm). It came at 11:30 this morning (thursday). That's really quick. That's not just really quick. REALLY quick. I don't live that far from Michigan, but it's still quick.
The finish on my car didn't need any polishing. There are a few little scratches that I'll have to take care of in the spring, but for now I decided to keep it simple today and enjoy the very warmy weather. It definitely didn't need claying; the paint was very smooth and somewhat slick still. Anyway...
Packaging.
This is the best box of detailing stuff I have received. The bottles are actually taped to a bottom piece of cardboard which is the same size as the bottom of the box. No wasteful packaging peanuts, just the bottles shrinkwrapped and taped. The towels and applicators come in ziplock bags.
And, SCOOP! An actual thank you! Yes, that orange envelope is filled with my detailed order information and a blue note thanking me for my order. When I ordered I had an issue with the website after hitting submit (I think this was really just an unfortunate consequence and not anything to do with the website). He included this in the letter. That's impressive. Many of you may recall my thread a year or two ago about this commonly overlooked detail. And he actually signed it too. It's these types of things that keep good customers.
And good bottles help, too. They're the perfect size to fit in a hand. Round bottles are so much nicer than square. When will people learn this? The tops are great. They're not those snap-slop-top design. Very nice.
Prime.
This is a great paint prep. Easy to work with and yields a good finish for the last protection step. It's certainly not going to do much for swirls. It seems to not be a great polish, but more of a cleaner. Klasse AIO? Yup. It seems like an updated version of that very product.
It's a fairly liquidy material. Watery perhaps. Not terrible, and it could definitely be worse. I just don't want people to be surprised when they notice that it's not thick like a off the shelf cleaner wax.
I applied it using my cylco random orbital with the white pads (polishing). I was originally thinking about using the blue (wax application) pads, but I thought that my paint could use a little polishing. This stuff spreads so easily, and you really don't need to use that much per panel (and sometimes I found the pads had enough to actually do half of another panel or that entire panel). Allow it to dwell on the paint for 30 minutes after working it well and it comes off without a hitch.
Easy to work with, great results, clean paint. Protection? I'm sure it provides some, and I do know of detailers that make their customers pay more for a wax or sealant after Klasse AIO, but I've never received great durability from AIO so I'm likely to believe Prime is similar. I could be wrong, this is just stipulation. The finish is certainly very slick after removal. Glossy and clear. Very clear. Crystal clear? I like that.
Clean pads (oh and that's MORE than enough to do, uhm, two panels. I wasn't sure):
Dirrrrty pads (I probably should have used two sets of pads for this):
Using a polisher seems to help get very even and thin application:
Acrylic Jett.
When I first popped open the flip cap I thought Klasse SG! Oh and I don't think I'm too far off. This stuff is thin. Water thin. Well not quite watery thin, but very thin. Thinner than the Prime. As thing as Klasse SG. After putting it on the pads and watching it be absorbed I thought about something.
If you'll notice Jeff includes another sprayer in the box. I thought that could be for the Acrylic Jett. Infact that's how I used to apply SG back in the day.......... So I put that on there and did a little spritzing action. Much better. Spray, spread, turn on polisher, and go to town.
Yes I used the cyclo with the blue pads. I have this thing about effective collisions. Now obviously we can't heat up the wax, but we can stir it around on the paint. And if not it just goes on quicker that way.
I did run into some problems:
If you get a spot where the Acrylic Jett is thicker (I understand that's a relative term--think of your neighbor waxing his car and actually going with a "thin coat." That's thicker--then I really feel sorry for you because this stuff loves to haze to a very hard shell. I was kind of mad (minus ease of use points for you, Acrylic Jett). Then I thought of a good saying, "Likes dissolve likes." I know many people quickly grab the quick detailer. I'm going to be honest: you're trying to mix oil and water and the only people that do that well are Kraft. So that was out--that quick detailer that was supplied probably wouldn't be much help. And if this truly is an acrylic then inducing water into the equation would likely diminish the "cross linking" and consequently the durability. Oh piddle.
So I grabbed the cylco with the pads still on it and damp with Acrylic Jett and reapplied to to these spots. Let it sit there for a bit and BAM it came off. Mindfully applying Acrylic Jett would prevent this altogether (ie watching for thick spots). I should note this only happened on the roof. It was more of a phenomenon and not really an entire car ordeal. The rest of the Acrylic Jett came off easily. Not as easy as Prime, but my arms weren't tired.
And the finish is just great. Clear! Pretty slick, too. However, it's easy to judge that when your hands are dried out from cleaners, so we'll see what I think about it tomorrow.
Oh I guess you probably want pictures of the car. The sun was still sort of out.
Modified by GoobDetailer at 9:23 AM 1/13/2006
Old Jan 12, 2006 | 09:46 PM
hadboosttroy's Avatar
Default Re: Review: Jeff's Werkstatt Prime and Acrylic Jett (GoobDetailer)
hehe, saw this on autopia
Old Jan 12, 2006 | 09:52 PM
DATZ WEAKSAUCE's Avatar
Default Re: Review: Jeff's Werkstatt Prime and Acrylic Jett (hadboosttroy)
holy bling
Old Jan 12, 2006 | 10:04 PM
VRD^sam's Avatar
Default Re: Review: Jeff's Werkstatt Prime and Acrylic Jett (DATZ WEAKSAUCE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DATZ WEAKSAUCE &raquo;</TD></TR><TR><TD CLASS="quote">holy bling </TD></TR></TABLE>
ATS*Mark's Avatar
OG triple OG
how much for the kit?
Old Jan 12, 2006 | 10:12 PM
DC2 to AP2's Avatar
Default Re: Review: Jeff's Werkstatt Prime and Acrylic Jett (Hella_JDM)
looks like great products... how much? my favorite that ive ever used and still do is tailors detailing products.
Old Jan 12, 2006 | 10:13 PM
astroxtc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM &raquo;</TD></TR><TR><TD CLASS="quote">how much for the kit?</TD></TR></TABLE>
Old Jan 12, 2006 | 10:18 PM
dFreezy's Avatar
Default Re: Review: Jeff's Werkstatt Prime and Acrylic Jett (astroxtc)
wow cool product. did you order it directly from jeff's website?
Old Jan 12, 2006 | 10:50 PM
eccentric.ek's Avatar
Old Jan 12, 2006 | 10:53 PM
B U N M A N G O's Avatar
I've been lacking in the detailing dept lately... too busy at work
good to see another Cyclo user too What do you think about the green cyclo pads? Have you tried any pads from other manufacturers for your Cyclo?
Old Jan 13, 2006 | 08:26 AM
The kit was $43 and change. It came to $51 and change with shipping.
That's actually funny that you asked that because I lost ONE green pad. Yes, only one. I was going to use them yesterday. I also have two orange pads, but I really need to type up a sheet for myself so I can keep these straight.
I don't see a huge difference between the Lake Country and the regular cyclo pads. I really HATE the yellow Lake Country pads. Hate isn't even strong enough. They just seem to dust more than they polish. The cylco pads aren't as thick, though. I really can't say which I like more--they're both good to keep around.
Old Jan 13, 2006 | 08:34 AM
Brice.Hayden's Avatar
Default Re: (GoobDetailer)
Nice work looks awesome.
It makes the paint look brand new.
I'm waiting for some idiot on here to tell you to slam your car...hahaha.
Very nice
Old Jan 13, 2006 | 09:50 AM
I HATE slammed cars. That isn't to say I don't think my car sits extremely high, but I wouldn't drop it too much. I'm saving for a new car in a few years. Possibly a Honda Fit to get me through pharmacy school. That'll be my reward for getting into pharmacy school.
Old Jan 13, 2006 | 09:54 AM
Francesco's Avatar
looks like good stuff...
Old Jan 13, 2006 | 10:18 AM
DUFFM4N's Avatar
Default Re: (Francesco)
Old Jan 13, 2006 | 10:53 AM
4aceM2's Avatar
wow
Old Jan 13, 2006 | 10:56 AM
fake mugen power's Avatar
great products. i am also a cyclo and PC user!
i dont really like the green pads from cyclo.
i perfer the lake country white pads.
Old Jan 13, 2006 | 10:59 AM
yee SERIOUS's Avatar
nice work!
Old Jan 13, 2006 | 11:00 AM
Skelly's Avatar
is that you corey?
Old Jan 13, 2006 | 11:03 AM
GSR-T-'s Avatar
dont ever say you hate slammed cars!.. ha jk.. nice product and presentation
Old Jan 13, 2006 | 11:14 AM
astroxtc's Avatar
Default Re: (GSR-T-)
link to buy
Old Jan 13, 2006 | 11:17 AM
accordselux's Avatar
Me Gusta History
Damn you might have beaten out my shining monkey on shiny factor
Old Jan 13, 2006 | 11:34 AM
HondaRider's Avatar
cleannnnnnnn
Old Jan 13, 2006 | 12:11 PM
Default Re: (Skelly)
yes, skelly, 'tis I!
Old Jan 13, 2006 | 01:32 PM
Default Re: (fake mugen power)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fake mugen power &raquo;</TD></TR><TR><TD CLASS="quote">great products. i am also a cyclo and PC user!
i perfer the lake country white pads. </TD></TR></TABLE>
yea, I'm not too fond of the green pads either... I really like the white polishing pads from LC for my PC... maybe I should get some for my Cyclo...
si90rex
Engine Management and Tuning
Nov 3, 2011 05:48 AM
speedracer33
28
Mar 4, 2006 09:11 AM
Jonathan_ED3
Audio / Security / Video
13
Jul 10, 2003 08:25 AM
Speed_Ricer99
Nov 21, 2001 07:22 PM
