got a LS with 43,000 opinions wanted
Hey i got a LS motor chillin in my garage with 43,000 on it....my intent is to work on it and keep dumpin money into it over the course of the next couple months. I then will swap it into my current LS when it is souped up. I am not interested in boost yet. I am into auto cross. I want the engine to produce mid range power, just slightly into the upper range. I am not wanting just hardcore high end power. I have looked into the LS/VTEC but it looks way to pricey and too much of a hassle because I dont know anybody that can do it in the Kansas City area. I am looking at a semi-aggressive set of cam's, some headwork, valve-train. I don't want to exceed $3,000 in this operation and I am hoping for higher 100's on horsepower and mid 100's on torque.....opinions please? (no boosting opinions, thanks)
if i were u i would get these parts an ls/vtec that thing
jdm itr .25 over sized pistons
shot peen yer stock rods
acl bearings
balance it all
gsr head milled 20 thous.
skunk 2 IM
skunk2 stage2 or maybe even stage3 cams depending on what kind of comp u get
springs reatainers
cam gears these will let u put yer power band where want it better.
and a golden eagle ls/vtec kit its hella easy to do no machine work needed.
crome
fuel pump
injectors
DC jdm 2.5 header cheap and they work good for the price
this is just a few parts u might be able to pull it off for 3 grand if u do a lot fo the work yerself GL
i know u said no ls/vtec but u might as well do it
acl bearings
balance it all
skunk 2 IM
springs reatainers
crome
fuel pump
injectors
hmm...are there any websites with instructions on how to do the VTEC conversion, I have a GSR laying around that is wrecked but I dont want to swap it because it has tons of miles. I don't know how to do the conversion is why i wanted to stay away from the LS/VTEC
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattcivic »</TD></TR><TR><TD CLASS="quote">
especially since you already have the head.
do u have any mechanic skills? im not ripping on ya im just saying if u have ever pulled and installed a motor and done some engine work as in like changing a head gasket u can do this its very easy. and if u have any doubts im sure u gotta have a friend or someone who can help u.
i dont really have any mechanic skills...i can take a head off and put it back on and all of that....but i have no idea about this plug stuff and wiring up the VTEC stuff....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fickel_8 »</TD></TR><TR><TD CLASS="quote">i dont really have any mechanic skills...i can take a head off and put it back on and all of that....but i have no idea about this plug stuff and wiring up the VTEC stuff....</TD></TR></TABLE>
You've got half the skills to do the required work already. All you need now is a little research.
Guest
Posts: n/a
yep take that head off that gsr and do some research, worrying about the miliage wont matter since youll be replacing alot of the internals. but theres ALOT of wirte up on ls/vtec installs so hit the search button man, it will be VERY worth it in the end. with that set up posted above youll have even more power than you want and PLENTY of torque for autocross. i had a similar set up to that in my ls/vtec crx and it put down 189hp TO THE WHEELS and 160something torque.
quikB18B
Apr 20, 2004 11:22 AM
sleepin91teg
Dec 23, 2003 07:33 PM
