i need some help PLEASE!!!!!!!!!!!!!!
Old Jan 12, 2006 | 05:55 PM
HondaCivicSiR1's Avatar
Default i need some help PLEASE!!!!!!!!!!!!!!
ok i'm putting a d15 from 93 eg and i wanted to know if anyone knows if it's ok to use a pr4 ecu on this engine i need some help asap
Old Jan 12, 2006 | 06:51 PM
crx.com's Avatar
Default Re: i need some help PLEASE!!!!!!!!!!!!!! (HondaCivicSiR1)
The 93 eg d15 would be 0bd1 and the pr4 ecu is a 0bd0 so I don't think that it works
Old Jan 12, 2006 | 08:11 PM
FOMULA91's Avatar
Default Re: i need some help PLEASE!!!!!!!!!!!!!! (crx.com)
It should work because I'm using a PR4 on my JDM D15B Vtec, and the motor is OBD0. Make sure you use your OBD0 Dizzy.
Old Jan 12, 2006 | 09:45 PM
d16vtecx's Avatar
Default Re: i need some help PLEASE!!!!!!!!!!!!!! (FOMULA91)
it will work but run rich
Old Jan 15, 2006 | 05:29 AM
Default Re: i need some help PLEASE!!!!!!!!!!!!!! (d16vtecx)
ok i have a new problem now i'm tring get the motor and trans together and i have notice that there is two coolant lines the are for the heater core and ef don't have two lines what should i do ?
Old Jan 15, 2006 | 02:02 PM
bump for some help
Old Jan 15, 2006 | 02:34 PM
da6jdmteg's Avatar
if you are talkin about the ones on the back of the motor you can replace that water journal with th one from your ef. were are they located?
Old Jan 15, 2006 | 03:00 PM
Default Re: i need some help PLEASE!!!!!!!!!!!!!! (da6jdmteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by da6jdmteg &raquo;</TD></TR><TR><TD CLASS="quote">if you are talking about the ones on the back of the motor you can replace that water journal with th one from your ef. were are they located?</TD></TR></TABLE>one is on the thermostat house and the other is on the side of the head and i know obd0 engine have the coolant fitting on the side of the only but this motor is obd1 so what I'll do is take some pics
Modified by HondaCivicSiR1 at 6:56 PM 1/15/2006
Old Jan 16, 2006 | 03:10 PM
bump for some help
bad 91 teg
Jan 21, 2011 04:17 PM
spoon93
Dec 25, 2010 10:22 PM
KRZRICAN
May 10, 2010 04:27 AM
slow hatch
Dec 21, 2007 10:07 AM
jbscivichb92
Feb 28, 2005 02:02 AM
