Quick MR5 lugcap question and picktures
What lug nuts do you use? I don't see a point to the alen head bolt, unless you have a hole drilled into your closed end lug nuts. I'm quite confused would someone like to help me out? :s
Myspace, I mean photoshop is fun!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOLtrain »</TD></TR><TR><TD CLASS="quote">not sure about ur question..all i can say is,those are gona look hot!</TD></TR></TABLE>
Thanks, they really do look good. I just need to get out and take some pictures. The one in the trunk was right when i got home from buying them and snapped a pic, and the other pic was late at night right after i put them on
I had to mess around alot to let you actually see most of the car
u use any open ended nut.
the allen bolts do nothing but allow u to pull the cap off. loosen the allen and it comes out a lil so u can remove it.
they do not attach to the lug or anything.
MINUS_the_
Feb 28, 2005 03:03 PM
