help with using newer cluster and a electronic vss, car is running obd1 harness
Old Jan 12, 2006 | 04:23 PM
darrinbrewer's Avatar
Default help with using newer cluster and a electronic vss, car is running obd1 harness
i'm usually in the teg forums, i dont visit crx/ef as i dont own one or work on any much.
i'm looking for links for help with this, my freind has a 91 si, running a chipped obd1 ecu with the boomslang harness and a obd1 dizzy.
lookin for info on convertiing the cluster to a newer, say 92-5 si, or a 94+ ls
but the car is cable for the speed, whats involved in usings a electronic vss from like a 92-5 d series. I'm guessing theres gonna be a wire to the ecu, and the guage cluster gets its info from the ecu, correct? because datalogging my chipped p05 shows the speed, temps and such.
thanks for any info
Old Jan 22, 2006 | 10:21 AM
Default Re: help with using newer cluster and a electronic vss, car is running obd1 harness (darrinbrewer)
been 10 days..no one got any info?
Old Jan 22, 2006 | 12:13 PM
jacoop86's Avatar
i didnt think there were si's in 92-95, but heres a writeup on a 99-00 si cluster in a ef. also has some electonic vss info
sorry about the link, here it is:
https://honda-tech.com/zerothread?id=709958
Modified by jacoop86 at 10:05 AM 1/23/2006
Old Jan 22, 2006 | 02:57 PM
Default Re: help with using newer cluster and a electronic vss, car is running obd1 harness (jacoop86)
you forgot the link.
and yes theres Si's in 92-5, the hatches, had sunroofs and all, the heaviest model, the only hatch with a d16z6 sohc vtec motor, your the 1st person i've seen not knowing there were 92-5 hatch si's...
96-8 didnt have one, then for the 1st time a coupe was labeled Si
Modified by darrinbrewer at 12:22 AM 1/23/2006
Old Jan 22, 2006 | 04:18 PM
hb_guy's Avatar
i just did this in my 91 ex 4dr, here is the link i used. these directions are for 96+ clusters. for 96 and up clusters and 94+ teg clusters you will need the two large cluster plugs from 96+ civics or 94+ integras(the plugs from both cars are interchangeable - ie., i used 94 integra plugs for my 2000 crv cluster)
my link (not a write up, just a prob i ran into and pics
https://honda-tech.com/zerothread?id=1490012
as for the vss, the first link should have your answer. and if you want to use 92-95 cluster (which there is no point - use a si, crv, or integra), you will have to use 92-95 civic plugs and function match the wires. g/l
Old Jan 22, 2006 | 08:23 PM
Default Re: help with using newer cluster and a electronic vss, car is running obd1 harness (hb_guy)
cool, thanks
Old Jan 22, 2006 | 09:44 PM
hb_guy's Avatar
no prob
jv88_dc2
May 10, 2010 08:55 PM
wesleywhite989
13
Jul 18, 2008 07:18 PM
4doorek96
May 31, 2008 04:10 PM
HybridEL
Feb 26, 2008 11:15 AM
Kataku2K3
Nov 6, 2002 02:22 PM
