Help ... 91 Integra Wiring Diagram For Alarm Install
Can't Find a wiring diagram for my car, Anyone have the info or layout? I would really appreciate it. 1991 Integra DA9. Installing Alarm and having problems. thanx.
12volts white or wht/blk + ign harness or fusebox
Starter black/white + ign harness or fusebox
Ignition black/yellow + ign harness or fusebox
Second Ignition blue/white + ign harness or fusebox
Accessory yellow + ign harness or fusebox
Power Lock green/white - either kick panel
Notes: Easier to locate at passenger kick panel. On drivers side, wires are located
high in kick panel.
Power Unlock green/red - same
Parking Lights+ red/green steering column
Door Trigger green/red - dr kick panel/fusebox
Notes: Looks like a 14 awg wire, but is mostly insulation.
Dome Supervision use door trigger
Trunk/Hatch Pin green/black - dr kick panel/fusebox
Tachometer blue AC distributor
Brake Wire green/white + brake pedal switch
Horn Trigger blue/red - steering column
Notes: This wire is high current negative, MUST use relay.
Interface Module: Category:
Immobilizer Bypass Required: None
This wiring information is being provided free of charge on an "as is" basis, without any representation or warranty. It is your responsibility to verify any circuit before interfacing with it using a digital multimeter.
Directed electronics, Inc. assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
high in kick panel.
