B18B into 91 hatch (4 spd.) ...
Old Jan 12, 2006 | 02:29 PM
na91hatch's Avatar
Default B18B into 91 hatch (4 spd.) ...
I have been set on swapping a b16a into my hatch in place of the stock d15 w/ the 4 spd. tranny. But recently have been almost talked into swapping a b18b instead. I can get one for $1600 with the computer. The best price I've found on a b16 is 1250 not including shipping with no ecu. Just give me some opinions. I want power. I know, horsepower costs money its about how fast you want to go. I'm trying to spend under $2000 on the entire swap if i go with a b18, which i think is possible considering the price of the motor itself. help me please.
Old Jan 12, 2006 | 02:54 PM
jlicrx's Avatar
Default Re: B18B into 91 hatch (4 spd.) ... (na91hatch)
if the B18B is $1600 by itself, no way you can get buy for $2000 - you still need a mount kit, shift linkage, axles, knuckles/hubs and exhaust, just for starters - you really should change the timing belt and water pump on the B18, as well as front and rear seals and pan gasket - you will need to convert wiring from DPFI to MPFI
Old Jan 12, 2006 | 03:19 PM
crxnj's Avatar
Default Re: B18B into 91 hatch (jlicrx)
Yeah maybe you should think about getting a b18a from a junkyard 90-91 integra(So you dont have to convert to obd1)..Get the motor/tranny/ecu/and hubs..Get some b-series hasport copy mounts off ebay for like $100,,get an aznracemachine linkage for like $75 or cut and re-weld the integra unit..Change the timing belt and water pump like jilicrx said..
Around here you can get those complete b18a swaps/w hubs for like $400-$500..Only problem is the motor may have high miles on it seeing how its a 13+ year old car
Old Jan 12, 2006 | 04:00 PM
d16vtecx's Avatar
1600 for a b18b is outrageous
they are about 600 out here
check hmotorsonline or passwordjdm
if you shop around you can put together the whole swap for 2 grand
Old Jan 12, 2006 | 04:35 PM
darrinbrewer's Avatar
your in SC, so a trip to 30 minutes or so west of Knoxville TN isnt too bad, call evans honda, http://www.evansautomotive.net (call for better/accurate prices)
here's a quote from the site
b18 non vtec (obd 1 or obd 2) complete drivetrain. $1,200-$1,800 (Depending on mileage) (and the offer shipping)
they're good about having ecus and giving you EVERYTHING needed. (i have a obd0 ls ecu here)
i've used the $150 ebay mounts
i have a freind thats good at rewelding the integra linkage for use in 88-91s, $80 is his fee, you could have evans send the linkage to me (they run a delivery truck up my way every other week or so, and it would only cost you 80 plus shipping it to you from me(1.5 hrs from ashville nc, in tn).
you could look for the newer/better b18b from a 94-5, the swap will have the dizzy and ecu, just get a boomslang harness and wire up the stuff, and your running obd1 and a better b18b with larger intake runners for only $110 or so more
Old Jan 12, 2006 | 04:36 PM
Default Re: B18B into 91 hatch (d16vtecx)
they also sell b16s with trannys for $1100 or so
Old Jan 13, 2006 | 08:38 AM
na91hatch's Avatar
Default Re: B18B into 91 hatch (darrinbrewer)
Sorry guys, i smoked a massive amount of crack yesterday. the b18 i can get for $1600 is a vtec (b18c?) it comes with the ecu and wiring harness. what model integra does that come out of? So id be spending bout $200 on linkage and mounts then another $100 on axles. What kind and where can i get the knuckles/hubs? Thanks for the help. i'm very b18-retarded. ANd what is the difference between a b18a and b
Old Jan 13, 2006 | 10:33 AM
crxnj's Avatar
Default Re: B18B into 91 hatch (na91hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by na91hatch &raquo;</TD></TR><TR><TD CLASS="quote">Sorry guys, i smoked a massive amount of crack yesterday. the b18 i can get for $1600 is a vtec (b18c?) it comes with the ecu and wiring harness. what model integra does that come out of? So id be spending bout $200 on linkage and mounts then another $100 on axles. What kind and where can i get the knuckles/hubs? Thanks for the help. i'm very b18-retarded. ANd what is the difference between a b18a and b</TD></TR></TABLE>
Well if its a b18c1 then it comes from the usdm integra gsr,,if its a b18c5 then its from the usdm type-r,,If it just says b18c then it could either be from the jdm integta sir-g or type-r..
As far as hubs you need 88-91 dx,ex,or si hubs,you could also use some integra hubs..
90-91 b18a - pre obd,130hp,comes in the 90-91 integra
92-93 b18a - obd1,140hp,comes in the 92-93 non gsr integra
94-95 b18b - obd1,142hp,comes in the 94-95 non gsr
96-01 b18b - obd2a/b 142hp,comes in the 96-01 non gsr
Old Jan 13, 2006 | 10:42 AM
ludesrv's Avatar
HOLY ****! B18B at 1600$???
Buddy you are getting RIPPED off. I can buy an LS complete for about 800$ Canadian, if the motor has low kms, even cheaper if the Kms reach then 150XXXkms.
Old Jan 13, 2006 | 10:46 AM
crxnj's Avatar
Default Re: (ludesrv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">HOLY ****! B18B at 1600$???
Buddy you are getting RIPPED off. I can buy an LS complete for about 800$ Canadian, if the motor has low kms, even cheaper if the Kms reach then 150XXXkms.</TD></TR></TABLE>
Can you read?? he made a mistake by saying b18b,and meant to say he's getting a complete b18c swap with wiring harness for 1600..
Old Jan 13, 2006 | 02:45 PM
Default Re: (Mr.speaker)
and if you found a complete b18c swap, thats a hydo tranny, your 91 is a cable style, so either you buy a cable tranny or run a hydro to cable adapter from hasport or someone else
DangercartSi
May 22, 2009 08:51 AM
ZCHF
25
Jul 27, 2004 01:45 PM
stevieteg
May 13, 2003 05:59 AM
2000Si-at-UK
Apr 24, 2003 05:40 PM
94si94cx
Oct 23, 2002 07:38 PM
