4x114 lug swap into 95 ls
Im getting the 4x114 lug conversion/swap from jdmtheory.com and had a couple of questions. can i use my e-brake cable? can i use my original brake calipers or will i need to get new ones or from a different car? when i need to replace the rotor which rotor do i order? if anyone has done this set up please let me know how the install was?
WELL U CAN USE YOUR EBRAKE CABLES THERE THE SAME..AS FOR THE BRAKE ROTOR U HAVE A COUPLE OF OPTIONS...1. ORDER THE JDM ITR 4X114 ROTOR. 2. GET GSR ROTORS AND REDRILL THEM..2. USE 92 LUDE ROTORS AND USE A SPACER...TO MAKE THEM WORK.. I CAN GET THE NEW JDM ITR 4X114 ROTORS..
I think you need the 94-96 Prelude VTEC rotors for the front. I don't know about the rear.
Check the dimensions here:
http://www.dba.com.au/DBASTDseries_cat.pdf
botlebruiser
Sep 5, 2006 05:16 PM
Ricey McRicerton
16
Sep 9, 2004 08:46 PM
