Headlight bulbs best and brightest help
Old Jan 12, 2006 | 12:50 PM
HondaJack's Avatar
Default Headlight bulbs best and brightest help
I am looking to get some better light out of my headlights. I live in the country and would really like to see the deer that run out onto the road a bit sooner.
What are the best bulbs I can get to put in there?
Are the Silverstars where it is at? I see other saying that they are better then Silverstar. Please help me out on this one.
Old Jan 12, 2006 | 12:56 PM
CRX Toad's Avatar
Default Re: Headlight bulbs best and brightest help (HondaJack)
Go to http://www.fourthgenhatch.com and look at the 9005 conversion. I have done this on my car and several other cars and with Silverstars you can light up the road. It is super easy to do also. Great cheap mod!!!!!!
Old Jan 12, 2006 | 02:08 PM
90efSI's Avatar
yea i did the conversion and it was a huge difference!!!
Old Jan 12, 2006 | 04:16 PM
HondaJack's Avatar
Default Re: (90efSI)
Thanks, I saw that mod and was planning on it. So I guess that the silverstars are the best bulb for that.
Ok silverstars it is,
Jack
Old Jan 12, 2006 | 04:24 PM
Stunna MIKE's Avatar
i have a question about this.. would you be able to cut the high beam wire and cut the low beam wire and wire the high beam to the low beam and vice versa.. if you get what im asking.. thanks
Old Jan 12, 2006 | 04:30 PM
Targa250R's Avatar
be professional
Default Re: (Aaron EF9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aaron EF9 &raquo;</TD></TR><TR><TD CLASS="quote">i have a question about this.. would you be able to cut the high beam wire and cut the low beam wire and wire the high beam to the low beam and vice versa.. if you get what im asking.. thanks</TD></TR></TABLE>
Umm . . . you would blind everyone travelling in the opposite direction if you wired up your high beams as low beams
Old Jan 12, 2006 | 04:33 PM
.... that is what this post is..
Old Jan 12, 2006 | 04:34 PM
Default Re: Headlight bulbs best and brightest help (CRX Toad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote">Go to http://www.fourthgenhatch.com and look at the 9005 conversion. I have done this on my car and several other cars and with Silverstars you can light up the road. It is super easy to do also. Great cheap mod!!!!!!</TD></TR></TABLE>
Isn't this the same **** ?
Old Jan 12, 2006 | 04:39 PM
Targa250R's Avatar
be professional
The 9005 conversion involves running a high-beam bulb in the low-beam housing, which is not quite the same as having your high beams permanently on.
Old Jan 12, 2006 | 04:46 PM
oh i see.. i want the DA look of the yellow 'fogs' on the inside light.. or highbeam for us EFers.. and the outside light.. or lowbeam as a bright white color
Old Jan 12, 2006 | 05:30 PM
crxmadman's Avatar
the sylvania "cool blue" 9005 conversion should be just fine. Silverstars are overrated, and if you're looking purely for light output, the cool blues will suit you as far as cost-perfomance goes
Old Jan 13, 2006 | 07:13 AM
HondaJack's Avatar
Default Lights
Any one know of any sites that compare the different bulbs?
Old Jan 13, 2006 | 07:49 AM
davens's Avatar
The 9005 conversion is a good place to start.
The Silverstars look great but they have considerably shorter lifespan than regular bulbs. According to Sylvania, their hi-perf "extra" halogen 9006 lasts 850 hrs.
The Siverstars average a paltry 150 hrs...which I consider ridiculous considering their price. If I had known about the shortened life, I wouldn't have installed them.
At any rate, considering the original poster's needs, they should be looking for a good PIAA, Hella or CATZ driving/fog light to supplement the weak *** stock headlights. Considering the cost of the buying four SStars($15-20 ea) and needing new ones every 150 hrs, a good driving light set looks like a bargain. Bulbs are not the answer.
Old Jan 13, 2006 | 07:54 AM
progress's Avatar
I was going to suggest the 9005 mod as well. AS soon as my CRX is back up and running, this is one of the first things I'm gonna do! Going a month without my car and having to drive my dad's underpowered 92 civic 4 dr automatic can drive a guy looney!!
BiG Chris's Avatar
i got the 9005 conversion in my projectors and it made a differnce then when my friend who has the same projectors installed a hid kit i know what im getting next
Old Jan 13, 2006 | 08:21 AM
HondaJack's Avatar
Default Re: (BiG Chris)
Humm I didnt know that about the SilverStars. That ends that idea. I think that I am just going to do the double 9005's and put on some mad fog/driving lights.
VTEC_Honda
Lighting
Mar 29, 2010 12:39 PM
xkrntamax
Nov 30, 2005 07:36 AM
8520
Apr 10, 2005 10:12 AM
broncoman74
45
Aug 4, 2003 05:09 PM
grngsr01
Sep 12, 2002 07:19 PM
