Jdm one piece wiring schematic
Old Jan 12, 2006 | 06:29 AM
hu's Avatar
hu
Default Jdm one piece wiring schematic
I am attempting to help my cousin install his jdm one piece headlights into his 4th gen lude this weekend. He is using 3 prong h4 bulbs (high beam, low beam, & ground). How do we make this fit with the factory wiring? Factory bulbs are 9006.
Thanks for the help
Old Jan 12, 2006 | 07:46 AM
bb4socal's Avatar
Default Re: Jdm one piece wiring schematic (hu)
Pepboys sells a conversion harness for h1 bulbs. Look in there "Ricer" section. All i did was splice all the wires. Obvious the black wire is gonna be ground and the others i just trial and error'ed. Youll have one wire on the conversion harness that you wont use. Just tape it up and tuck it away.
Old Jan 12, 2006 | 07:54 AM
iakona's Avatar
don't you need the H4H bulbs?
and yeah, i did the same for my DA. got one H4 harness and one 9007 harness and spliced them together. plug and play with no downtime.
Old Jan 12, 2006 | 01:20 PM
94Vtecluder's Avatar
Default Re: (iakona)
Here is a walk thru for the whole process
http://absoluteprelude.com/for...ID=45
basically you have to cut your wiring harness and rewire new sockets to it. It's very easy tho. Here is the diagram
Here is a picture of the socket you will need to solder to your harness after you cut off the old 9006/9007 bulbs harness.
Now for the high beams you also need a special adapter. They are like 30-40 dollars tho. I belive the high's are H1's, they have one prong but you have to buy an adapter to make it 3 prong to fit the new harness you soldered in. Here is a picture showing what I mean.
See, the high beam bulb is wierd. Anyway good luck, process should be very easy believe it or not.
Old Jan 12, 2006 | 08:00 PM
hu's Avatar
hu
Thanks for all the help. You guys saved us a lot of hassle.
Wagonist
Apr 12, 2016 01:39 PM
Rok_Stok
Aug 16, 2011 11:06 PM
monalisa overdrive
Nov 2, 2004 11:15 AM
Bklyn TSi
Oct 23, 2002 01:54 PM
