itr sway bar
Old Jan 11, 2006 | 09:00 PM
94IntegraLs04's Avatar
Default itr sway bar
ok guys i install my jdm itr sway bar in my 94 ls with the bsq kit. ight everything is good i luv the handling wow is good but one problem my loud as exhaust is ratling with the sway bar.anyone out or in here has an exhaust tht is not loud tht sound good tht wont hit the sway bar at the same time i was thinkin of the t1r,hi power,itr,or the exmag.
there it is
there were is rubbing
Old Jan 11, 2006 | 09:13 PM
Erik95LS's Avatar
Default Re: itr sway bar (94IntegraLs04)
your swaybar is on upside down
WhoDoYouThink's Avatar
Pm'd you
Old Jan 11, 2006 | 09:16 PM
hobo_ken's Avatar
Default Re: itr sway bar (Erik95LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Erik95LS &raquo;</TD></TR><TR><TD CLASS="quote">your swaybar is on upside down</TD></TR></TABLE>
Old Jan 11, 2006 | 10:49 PM
Chubakon's Avatar
Default Re: itr sway bar (hobo_ken)
i had this problem on my integra before as well... i just tie the exhaust a little higher....
if it's upside down...does it effect the performance of the sway bar?
Old Jan 11, 2006 | 11:04 PM
Erik95LS's Avatar
Default Re: itr sway bar (sohc SOL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohc SOL &raquo;</TD></TR><TR><TD CLASS="quote">i had this problem on my integra before as well... i just tie the exhaust a little higher....
if it's upside down...does it effect the performance of the sway bar?</TD></TR></TABLE>
I don't know if it'd really hurt it, but it certainly couldn't be beneficial. The bar is curved that way for a reason. Also......I could see it easily binding on the endlink the way his is installed.
Very simple fix though. Just flip it over the other way and you won't have to worry about it hitting the exhaust or not working properly.
Old Jan 12, 2006 | 03:27 AM
thnx i c now danm. so wut exhaust i can put tht it wont.be so noise from the ones i listed on top
Old Jan 12, 2006 | 03:42 AM
an one more question guys. i want to install tht greys bar tht comes in the jdm itr only tht is in the trunk part by the rear black panel. is there a tread on how to install tht is the trunk brace
Old Jan 12, 2006 | 06:20 AM
Erik95LS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94IntegraLs04 &raquo;</TD></TR><TR><TD CLASS="quote">thnx i c now danm. so wut exhaust i can put tht it wont.be so noise from the ones i listed on top</TD></TR></TABLE>
none of those including the one you have on the car should rattle once you put the bar on right.
Old Jan 12, 2006 | 06:36 AM
DJ Gurgla GSR's Avatar
http://www.geocities.com/bretq....html
Old Jan 12, 2006 | 05:42 PM
Default Re: itr sway bar (DJ Gurgla GSR)
thnx guys well i put tht trunk brace today ill take some pics soon is nice
Old Jan 12, 2006 | 10:20 PM
SOHC_me's Avatar
what bennifits do you get from the trunk brace, does it help stiffn the chassis?
Old Jan 12, 2006 | 10:35 PM
dFreezy's Avatar
Default Re: itr sway bar (dc_mike)
in theory, although it likely adds very little 'stiffening'
Old Jan 13, 2006 | 11:56 AM
sleepinggsr's Avatar
Try using the subframe reinforcement kit. That will stiffin up more, if that's what you wanted. It worked for me. Go on to http://www.A-spec-racing.com Tell Charleston Lou recommended you.
Old Jan 13, 2006 | 12:27 PM
Solscud007's Avatar
Default Re: itr sway bar (sleepinggsr)
i didnt see one for the DC on there.
Old Jan 15, 2006 | 12:46 PM
Default Re: itr sway bar (Solscud007)
it's about the same thing as the eg...I forgot what the difference was.
Old Jan 15, 2006 | 12:55 PM
you can also check on http://www.passwordjdm.com...that one's there.
Old Jan 16, 2006 | 05:44 PM
does anyone in here has the itr sway bar except me. tht has the hks hi power on it
i wanna some pic
Old Jan 16, 2006 | 06:28 PM
Erik95LS's Avatar
I have the bar with the BSQ kit and my car is even the same color. It doesn't touch my HyTech exhaust which is monstrously huge back there. It comes very close to the bar, but does not touch. I've had a few exhausts on my car with this and not one of them has ever rattled.
Did you put it on right? I'm willing to bet that once you do the bar is nowhere near the exhaust. I'll look for a pic.
Old Jan 16, 2006 | 06:49 PM
integra95gsr's Avatar
which is better? the stock gsr front sway bar and the itr rear sway bar?
Or the Suspension Techniques kit?
ive read about everyone using a beak's or a BSQ Kit for the ITR rear sway bar, is this something you would also need for the ST Kit?
aemintgsr
Jan 19, 2008 05:09 PM
5Point7Liter
Suspension & Brakes
11
May 2, 2007 10:16 AM
94maroonturbocp
Oct 29, 2004 08:31 PM
powerls
Jan 19, 2004 08:38 AM
nY's FiNeSt
33
Oct 16, 2003 12:47 PM
