hx wheels
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jst another DA »</TD></TR><TR><TD CLASS="quote">ya i know it sucks i have to shave mine down tomorrow ..what if i ran wheel spacers</TD></TR></TABLE>
You can do that also, but id rather shave the caliper down.
Modified by NAisBEST at 11:06 AM 1/12/2006
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAisBEST »</TD></TR><TR><TD CLASS="quote">then youre just pushing the wheel further out, and it still wont fit. Shave the caliper
You're an idiot. Don't give people advice anymore if you have NO idea what you're talking about.
Spacers work just fine. That's what I used when I had those wheels on my car.
</TD></TR></TABLE>You're an idiot. Don't give people advice anymore if you have NO idea what you're talking about.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Have an STD »</TD></TR><TR><TD CLASS="quote">yeah, mr knowledge, well spacers are not as safe as shaving the caliper. id rather shave the caliper a bit than thread my lug nuts on 4 less turns
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Have an STD »</TD></TR><TR><TD CLASS="quote">you need to lay off the hatorade dude, you never have ANYTHING good to say about anyone
Brett,
Let's say that YOU were the one that wanted to put HX wheels on your car. You ask if you could use a simple spacer to make the wheels clear the brakes, and some kid tells you:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAisBEST »</TD></TR><TR><TD CLASS="quote">then youre just pushing the wheel further out, and it still wont fit. Shave the caliper </TD></TR></TABLE>
So, you take the advice from the kid that spouts some off the wall **** about pushing the wheel out not clearing the caliper. You would have gone and done a PERMANENT change to your car by shaving material from your caliper when you could have got some dirt cheap *** 5mm spacers and the wheels would fit 100%
Just because YOU would rather shave the calipers doen't mean the OP does, and it doesn't make the shitty advice given by NAisBEST any less wrong.
I don't need you calling me a hater when I call an idiot an idiot. Quit your FUC KING BITCH ING.
Brett,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kNOwLedGeDA9 »</TD></TR><TR><TD CLASS="quote">
Brett,
I don't need you calling me a hater when I call an idiot an idiot. Quit your FUC KING BITCH ING.</TD></TR></TABLE>
im gonna have to say owned to that
Brett,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DUFFM4N »</TD></TR><TR><TD CLASS="quote">
I second this.
</TD></TR></TABLE>I second this.
first time i grinded them doen and ended with this ...
i know it's on eg but ....their is the right way with bigger brake's and 5 mm spacer's...
so basically get some extended stud's and 5mm spacers....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drevinder »</TD></TR><TR><TD CLASS="quote">first time i grinded them doen and ended with this ...
so basically get some extended stud's and 5mm spacers....</TD></TR></TABLE>
exactly, you ruin your perfectly good calipers, and gonna have to fork out $$ when you decide to change your wheels.
Run the wheel spacer like everyone said, and you'll have no probaly what so ever.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ECAhatch »</TD></TR><TR><TD CLASS="quote">i'd space it out, rather than shave the caliper. </TD></TR></TABLE>
exactly
exactly
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kNOwLedGeDA9 »</TD></TR><TR><TD CLASS="quote">You're an idiot. Don't give people advice anymore if you have NO idea what you're talking about.
Spacers work just fine. That's what I used when I had those wheels on my car.</TD></TR></TABLE>
Wow, dude, you need to calm yourself down. Theres no reason for name calling through a keyboard. We dont need these type of childish responses on an online information board. A simple, "no i disagree" would suffice.
I purchased a set of wheel spacers from the local auto parts store because my hx wheels wouldn't clear my ex front brake calipers. They're the UNIVERSAL Mr. Gasket - Wheel Spacer, 1/4'' Thick (about 6mm), Fits 4-''4.25'', 4-Lug Bolt Pattern...they did the trick for me. Plenty of clearance and no need for extended studs. $23.00 at O'Reily Auto Parts.
Here they are at JEGS: http://www.jegs.com/webapp/wcs...18581
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gabebauman »</TD></TR><TR><TD CLASS="quote">&categoryId=18581]http://www.jegs.com/webapp/wcs...18581[/url]
Car looks gooooood
</TD></TR></TABLE>Car looks gooooood
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Have an STD »</TD></TR><TR><TD CLASS="quote">MR KNOWLEDGE GOT BANNED HAHAHAHAHA</TD></TR></TABLE>
Thank you to the MOD thats keeping this forum in order and free of BS.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Have an STD »</TD></TR><TR><TD CLASS="quote">they are gonna be rare cause u have to shave the caliper to get themto fit. hx wheels dont clear 10'' brakes which ALL DA's have</TD></TR></TABLE>
I think all you need is a spacer for the wheel and it will work. I had a friend with a da with and he didnt shave ****, he just used a spacer.
talk about misinformation. the wheels dont clear by 2mm, all you need is a 3mm spacer from Discount Tire for $10 and you can run them all day long. 3mm isnt going to make any difference at all.
</TD></TR></TABLE>talk about misinformation. the wheels dont clear by 2mm, all you need is a 3mm spacer from Discount Tire for $10 and you can run them all day long. 3mm isnt going to make any difference at all.
damn looking real good
