engine work
Old Jan 11, 2006 | 07:35 PM
speedncivic's Avatar
Default engine work
I want to take by B18c1 and bore it to 84mm and put a set of sleeves in it with 9.0:1 compression JE pistons and eagle rods. Is this a good idea? I dont know much about boring out a motor,and sleevign it. All I know is low compression is better for boost. Is it better to have more mm's when boring for boost or should I leave the block's 81mm bore alone and sleeve that. Shouls I sleeve it at all or what? What is a good set of sleeves for boost. Can somebody break it down on the best way to build a block for boost? I mean, bore it or not, sleeve it or not, compression up or down. Please help me before I ruin a great block.
Old Jan 11, 2006 | 07:41 PM
Baggy Spandex's Avatar
Default Re: engine work (speedncivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedncivic &raquo;</TD></TR><TR><TD CLASS="quote">I want to take by B18c1 and bore it to 84mm and put a set of sleeves in it with 9.0:1 compression JE pistons and eagle rods. Is this a good idea? I dont know much about boring out a motor,and sleevign it. All I know is low compression is better for boost. Is it better to have more mm's when boring for boost or should I leave the block's 81mm bore alone and sleeve that. Shouls I sleeve it at all or what? What is a good set of sleeves for boost. Can somebody break it down on the best way to build a block for boost? I mean, bore it or not, sleeve it or not, compression up or down. Please help me before I ruin a great block. </TD></TR></TABLE>
If you dont have the money, do not build a motor. It is not cheap, and you do NOT want to cut any corners whatsoever. Safe compression is all in the eye of the engine builder/tuner. STRONG internals and proper clearances are key. The norm is about 9.5 to one, but like I said, thats all up to the builder. If you bore the motor, do not look to rev it very high unless it is sleeved, and if you do sleeve it, have a reputable person press the sleeves...such as Golden Eagle of Benson's in house services. If I were you, and I wanted to sleeve my motor and build it for boost (which is against my religion ), I'd try to find a spare block somewhere else for cheap and build that one, this way there's no downtime while your only motor is out of the car being built.
Old Jan 11, 2006 | 07:47 PM
x_outlaw_x's Avatar
yeah, dont build the only motor you have...look around and pick up a b18c block to build
Old Jan 12, 2006 | 11:18 AM
This is not the only motor I have, It in fact is the one I bought . So my car will not be down for long. Golden eagle sleeves are a good sleeve to use?
Old Jan 12, 2006 | 12:02 PM
x_outlaw_x's Avatar
go to http://www.inlinefour.com...all of the products there are pretty good quality and that is theo nly place i buy my engine parts
Old Jan 12, 2006 | 12:04 PM
Default Re: (speedncivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedncivic &raquo;</TD></TR><TR><TD CLASS="quote"> Golden eagle sleeves are a good sleeve to use? </TD></TR></TABLE>
B16afmaxt
Nov 11, 2009 04:27 PM
Mechman456
Honda Civic (2006 - 2015)
Nov 6, 2007 11:25 AM
osaka777
Jan 16, 2007 11:01 PM
b18sihatch
Nov 18, 2006 08:11 AM
Bspec18
May 25, 2003 11:08 PM
