**** Civic EX w/ B16A2 Swap ??? ****
Old Jan 11, 2006 | 07:32 PM
vipersr10's Avatar
Default **** Civic EX w/ B16A2 Swap ??? ****
Hello I have question Im currently looking to buy a vehicle and was hoping to get some opinions and suggestions. The description shows as follows:
1997 CIVIC, 98k mi, 67k miles on motor, air bag, ac, ps, cc, tilt, pwr windows, am/fm, pdl, pwr mirrors, sunroof, EX Chassis, white w grey interior. B16A2 Engine and tranny swap, Skunk2 Stage 2 cams, Upgraded Springs and Retainers stock valves, modded suspension,clutch, exhaust, chipped P28 ecu, MSD Ignition, Fields Fuel/Vtec Controller.$6,200
From what the seller told me the block seems to be stock and all the work that has been done has been on the head. MY question basically is weather or not this is a good setup or not? Is it reliable? Stage2 cams able to make power with no block work? Is there nething else required to run Stage 2 cams besides retainers and springs? Also is $6,200 a good price?
Old Jan 11, 2006 | 07:35 PM
HATCHingMN's Avatar
Default Re: **** Civic EX w/ B16A2 Swap ??? **** (vipersr10)
price is pretty fair
Old Jan 11, 2006 | 07:39 PM
vipersr10's Avatar
what about the engine setup? How does that sound?
Old Jan 11, 2006 | 07:42 PM
bmoua's Avatar
engine setup sounds good...you can just add on to those mods bro...the car itself looks clean...try to lower the price to under 6g's
Old Jan 11, 2006 | 08:36 PM
.Ry's Avatar
.Ry
I would say $6K, because I bought my 97 with 120K on the ticker for $4250. The swap would take me to $6K alone. So the $6200 is fair but I would try for $6K
Old Jan 11, 2006 | 08:40 PM
r_Senik's Avatar
Default Re: **** Civic EX w/ B16A2 Swap ??? **** (turner7205)
yea the motor sounds good...its look like it was a clean swap.
but yea try to get it atleast under 6200. about 5600-5800 sounds ok..plus the shell looks good
Old Jan 11, 2006 | 08:50 PM
FuNkDrSpOt's Avatar
on kbb.com, a good condition vehicle with that many miles is $5300 through private party. Personally if you think the motor was swapped over well and it is C.A.R.B. legal ( which it probably isn't since i see an Orange on the license plate ) then I would go for it at the price its at. Of course you always want to bargain but its a bargain @ the price it's at if the swap itself was done right.
If you want to think about it another way, almost everything that makes the difference between an Ex and an Si has already been upgraded on this car. An Si with 67k miles goes for $10k.
Get a compression and leakdown test done first before you buy this thing. I would negotiate that the seller pick up that tab if it fails and you pick it up if it passes. Maybe shoot for $6.2k - cost of tests.
Old Jan 11, 2006 | 08:59 PM
gunmetalej's Avatar
Default Re: **** Civic EX w/ B16A2 Swap ??? **** (FuNkDrSpOt)
get a leak down and compression test done before you buy it. I had basically the same car and when i sold it i got 6600 but i would have taken 6 for it.
Old Jan 12, 2006 | 03:38 PM
vipersr10's Avatar
wats a leak down test? Also how much hp do you think the motor should make with skunk 2 stage 2 cams and the p28 cpu?
Old Jan 21, 2006 | 05:35 PM
Dub C's Avatar
Default Re: (vipersr10)
B16... Buy it, race it, guarantee you'll like it... I wish I had one. 160hp!!!
Old Jan 21, 2006 | 07:06 PM
Vero's Avatar
I wouldnt touch that car with a 10 foot pole.
I can tell you one of 2 things.
1) either the motor is not a real b16a2, in which case it most likely OBD1 and illegal to be in the car. (important for cali and emission bearing states)
or
2) That motor is most likely stolen, the VIN has been removed and you can see the remaining rivet holes.
Which means if you ever get stopped/checked, that cop has a reason to impound your car.
Better hope the owner has legitimate paperwork to give you for the sale of the motor.
bluehondasi2000
May 15, 2011 09:02 AM
MexicanJDM
Mar 31, 2008 05:03 AM
LDTFbsst
Feb 18, 2008 05:09 PM
mountaindewguy
Oct 12, 2006 02:26 PM
VTECVillain
Feb 12, 2003 04:30 PM
