Break pedal hits the floor? 95 Dx Hatchback.
Old Jan 11, 2006 | 04:30 PM
dem0nk1d's Avatar
Default Break pedal hits the floor? 95 Dx Hatchback.
Changed front pads, rear drums, and shoes. Bleed system of any air. The car still doesn stop worth a damn like it should. Also the rear drums, make a dragging/scrapping sound when slowing down.. I don't belive it should sound like this. If all fails i am switching to disc in the rear...
Old Jan 11, 2006 | 04:32 PM
SOHC4life 96's Avatar
Default Re: Break pedal hits the floor? 95 Dx Hatchback. (dem0nk1d)
You think you bled them enough? Go bleed them some more, and when you think your done, bleed them some more. It's a pain in the ***, but that's the only possible problem/solution.
Old Jan 11, 2006 | 04:34 PM
Tippyman's Avatar
MC ok?
Old Jan 11, 2006 | 04:36 PM
-Gambit-'s Avatar
Default Re: Break pedal hits the floor? 95 Dx Hatchback. (SOHC4life 96)
bleed them some more. Starting with the one furthest from the mc and work your way forward
Old Jan 11, 2006 | 06:00 PM
hondanick67's Avatar
You should check ur master cylinder for leaks and u should see if ur brake booster is holding it air, u should also bleed the brake lines until there is no more air coming out and then let it go a few more seconds. Make sure the master cylinder resivoir is full at all times. The bleeding process goes with the RR, RL, FR, FL I hope ur problems go away later
Old Jan 11, 2006 | 06:12 PM
MOUNTAINGARAGE's Avatar
do a test inspection with the car jacked up so you can put an ear on the back brakes, if needed, Pull your drums to see if the shoes are still lined up properly on the wheel cylinder, or if it is good. good luck....
V-8 who
Oct 14, 2011 08:49 PM
DO/\/\O
20
Sep 10, 2011 08:22 PM
dleccord
Jan 3, 2010 08:39 AM
ice11honda
Feb 24, 2005 12:56 PM
WSG_buBble
Apr 2, 2004 09:40 AM
