need to find
From: if you build it they will come, the bottom carolina, duh
i am trying to figure out what is wrong with the a/c, so my question is which relay is the a/c clutch relay.
thanks in advance
thanks in advance
Was it cold when it die or crap on you?
Do you hear the compressor kick when you press the ac button?
Do see the compressor turnning?
read a voltage at the switch see if you get any.
If not probably your relay is bad.
If you get voltage and your compressor doesn't kick on.
It could be you are low on freon or your clutch is gone.
Check your ac pressure
i already have checked the level and also the voltage(none) thats why i want to change the relay b/c i think it is that and b/c i want to change it just b/c it is old anyway.
how do you wire the vtec to the a/c relay i was reading another forum you were in about wiring the pm6 with vtec, that is another reason i want to figure out where the relay is. and i didn't know that the a/c clutch was built into the ecu.
akb427
Honda Civic (2001 - 2005)
Jun 28, 2013 08:51 AM
jhiz
Jun 22, 2004 08:37 AM
