Where to focus money for the turbo build?
Okay, been doing lots of research, I know the majority of what needs to be upgraded, pistons, rods, sleeves, valvetrain, fuel, engine management, lsd, clutch, etc. I'm going to have about $5000 to spend, and I don't think I'll be able to afford all the upgraded parts plus the actual turbo kit. I'm going to do 90-100% of the labor myself (me and my uncle). So where should I focus the money I have to spend? Or does anyone think the whole build can be done for $5k? And $5k is the maximum, I want to save $1k for emergencies.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by plikit »</TD></TR><TR><TD CLASS="quote">Okay, been doing lots of research, I know the majority of what needs to be upgraded, pistons, rods, sleeves, valvetrain, fuel, engine management, lsd, clutch, etc. I'm going to have about $5000 to spend, and I don't think I'll be able to afford all the upgraded parts plus the actual turbo kit. I'm going to do 90-100% of the labor myself (me and my uncle). So where should I focus the money I have to spend? Or does anyone think the whole build can be done for $5k? And $5k is the maximum, I want to save $1k for emergencies.</TD></TR></TABLE>
Turbo - ~650
Pistons ~500
Rods ~300
(sleeved ~1200)
Wastegate ~150
BOV ~150
Fuel pump ~100
Fuel rail ~120
Fuel regulator ~120?
injectors ~350
oil lines ~90
piping ~140
manifold ~300
2hr dyno tuning ~500
hondata s300 ~750
**** like that - thats off the top of my head - so, costs may be more or less.....
That right there is roughly 5400...........
You have to get other things like spark plugs, gaskets........**** like that...........
Turbo - ~650
Pistons ~500
Rods ~300
(sleeved ~1200)
Wastegate ~150
BOV ~150
Fuel pump ~100
Fuel rail ~120
injectors ~350
oil lines ~90
piping ~140
manifold ~300
hondata s300 ~750
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 »</TD></TR><TR><TD CLASS="quote">a fast na prelude...</TD></TR></TABLE>
A fast NA Prelude?
Never heard of one
A fast NA Prelude?
Never heard of one
I dont think you need a valvetrain upgrade for a turbo setup if you're cutting costs. 5K is close to being right where you need for a decent turbo setup, but not completely built. Building your motor is already 2K, 3K wont get you a nice turbo along with ECU and dyno tuning. Gotta get some more money or cut some corners haha.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by homesauce »</TD></TR><TR><TD CLASS="quote">I dont think you need a valvetrain upgrade for a turbo setup if you're cutting costs. 5K is close to being right where you need for a decent turbo setup, but not completely built. Building your motor is already 2K, 3K wont get you a nice turbo along with ECU and dyno tuning. Gotta get some more money or cut some corners haha.</TD></TR></TABLE>
have you seen my car? i think its a lil better than a decent turbo set up and build......... golden eagle sleeves, endyn rollerwave pistons, full race/manley rods, tuned with NEPTUNED, brand new precision pt61 turbo, brand new precision large front mount, new tial bov, new equal length manifold, 400whp, under 5k... enough said
Modified by john d at 1:05 AM 1/12/2006
with $5K i would build my own turbo kit, >$2000 easy.
Then the rest would go towrd a set of Mahle Gold series pistons and some manely rods.
But thats just me and I think that could make a mean 350+hp prelude.
Edit: Back to the topic, I say the Focus should go to forged internals and fuel management.
after you have all of your parts together. make sure you saved enough to invest in tuning. people like to skimp out at this part (i learned the hard way the first few motors, lol). get your stuff tuned by a reputable shop/person. Like KingPin said, said hondata and dyno tuning. My friends use crome, neptune, and a few go over to Jeff Evans. anyway, good luck with your build.
thanks a bunch you guys, i guess ill be saving a little longer. i should start keeping my eye out now for good deals on parts i need. the only thing is im iffy about piecing together my own turbo kit. i dont want to buy something uncompatible with other parts.
on a another note would it be a good idea to build the internals and drive it for a while (until i get enough money for a turbo)? is there any kind of break-in needed before a turbo should be installed after replacing all those internal parts?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheKINGPin »</TD></TR><TR><TD CLASS="quote">
Turbo - ~650
Pistons ~500
Rods ~300
(sleeved ~1200)
Wastegate ~150
BOV ~150
Fuel pump ~100
Fuel rail ~120
injectors ~350
oil lines ~90
piping ~140
manifold ~300
hondata s300 ~750
You have to get other things like spark plugs, gaskets........**** like that...........</TD></TR></TABLE>
what sleeves cost 1200? this include installation? because i can get the labor for free. my uncle works at a shop.
Turbo - ~650
Pistons ~500
Rods ~300
(sleeved ~1200)
Wastegate ~150
BOV ~150
Fuel pump ~100
Fuel rail ~120
injectors ~350
oil lines ~90
piping ~140
manifold ~300
hondata s300 ~750
You can try to do all of this for 5k, but first time around you won't pull it off. I also bet that if you try this build for this 'budget' you'll be redoing it again in the very near future. Honda engines have very tight tolerances and if your uncle has not sleeved a honda block before, I don't recommend he learns on yours.... unless you have another $5k to spend.
In my opinion, a GOOD turbo kit (turbo, IC, piping, oil lines, fuel upgrades, EMS, tuning) is going to run you an easy $4000 alone.
hmm, some say 5k is do-able some of you say not even close. dont worry about my uncle he's been a building cars for about 30 years. and not just muscle cars, hes built tons of supercharged motorcycles that run clearances/tolerances as tight as honda.
what would most of you recommend a good budget to work with be?
