93 accord auto to manual swap yes i searched couldnt find the answer
Old Jan 11, 2006 | 02:24 PM
viciousvisionslarry's Avatar
Default 93 accord auto to manual swap yes i searched couldnt find the answer
ok i have a 93 accord 4dr auto i bought all the stuff to do the 5spd swap all new 5spd mounts will the motor and trans bolt in?everything ive seen is for a newer model and says to drill a new hole in the mount on the tranny side but the pictures are not the right mount?has anyone done this already?
Old Jan 18, 2006 | 02:31 PM
92accordEX4life's Avatar
Default Re: 93 accord auto to manual swap yes i searched couldnt find the answer (viciousvisionslarry)
Yes! If you have a 90-93 accord manual trans then it should bolt right up to the block. I have a 92 accord EX coupe and I switched it to manual cause my auto died on me. It cost me about the same to change it to standard then to have them rebuild my auto trans...it cost me about $1400-$1500 dollars. Also make sure that you have the tranny mount that comes with the tranny that is the only mount you will need considering you have: d/s axel, p/s axel, halfshaft, shift linkage, pedals, shifter, hydrolic fluid resivouir w/ line,new clutch & flywheel and all the clips and bolts. GOOD LUCK!
Old Jan 18, 2006 | 02:51 PM
P_Adams's Avatar
Try this:
courtesy of Accordinglydone.com
http://accordinglydone.com/for...=9624
P
97civixlx
Nov 25, 2016 11:36 AM
Rethelann
Oct 22, 2014 11:07 PM
JOeiROck
Mar 2, 2006 10:22 PM
rillboss
Jan 16, 2005 09:50 AM
cokane5227
Sep 1, 2004 03:11 AM
