Priming a Windshield Washer Pump
Old Jan 11, 2006 | 10:43 AM
o2flow.net's Avatar
Default Priming a Windshield Washer Pump
ok so I think the windshield washer pump on my EJ has finally bit the dust. When I bought a new pump, the computer at AZ said the pump needed to be primed before installing? Any idea if this is true or not? would I just run the pump with my fingers over the holes before installing?
Old Jan 11, 2006 | 11:01 AM
VTcivicHB's Avatar
Nope you should be good. Just put fluid in the reservoir after you install in and you should be good to go.
Old Jan 11, 2006 | 11:48 AM
Tippyman's Avatar
Default Re: Priming a Windshield Washer Pump (o2flow.net)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by o2flow.net &raquo;</TD></TR><TR><TD CLASS="quote">ok so I think the windshield washer pump on my EJ has finally bit the dust. When I bought a new pump, the computer at AZ said the pump needed to be primed before installing? Any idea if this is true or not? would I just run the pump with my fingers over the holes before installing?</TD></TR></TABLE>
Never heard of that.
jdm_h22
Mar 4, 2013 07:15 PM
ahobbs
Feb 23, 2011 11:08 AM
boostincoupe
Sep 10, 2003 11:51 AM
94dxt
Apr 1, 2003 03:57 PM
