Cooling System Help!!
Old Jan 11, 2006 | 10:11 AM
drpapi45's Avatar
Default Cooling System Help!!
OK guys...MY car doesnt blow hot or cold air...also the temperature gauge stays cold (it does not move an inch).......what could be causing this problem??? Thanks for the suggestions
Old Jan 11, 2006 | 10:23 AM
drpapi45's Avatar
Default Re: Cooling System Help!! (drpapi45)
sorry its a 94 accord ex 4 door
Old Jan 11, 2006 | 11:25 AM
amckee's Avatar
So are you saying that the blower motor is not working and your temp guage doesn't move at all? Does the engine get hot? Does it overheat? Do the Upper and lower radiator hoses both get hot?
Old Jan 11, 2006 | 11:37 AM
P_Adams's Avatar
Has this car gone for a long time without some attention? It sounds like you have several issues.
Taking it in the direction that amckee has started, it's possible the car is in dyer need of a thermostat, there's insufficient coolant in the system or insufficient coolant flow to the heater core.
On the Heater Blower Motor issue:
After you've checked ALL the fuses and are assured they're all good, I would offer the time honored "Crow Magnon Approach" to blower motor diagnosis. IE:
Turn on the ignition key, turn on the blower fan and:
Locate the blower motor up behind your glove box and give it a whack (Upside the head) with a metric hammer.
WTF, you ask?
You actually run into situations where things on Honda's don't break, but rather wear out over the course of the cars life.
Case in point; your blower motor. The brushes may have worn out.
Sometimes a whack will reestablish (momentarily) the brush connection, and the blower will start working again. If it responds, get a new blower motor. If it doesn't, suspect the switch
P
Modified by P_Adams at 8:57 PM 1/11/2006
Old Jan 11, 2006 | 11:49 AM
accord99's Avatar
mabe your house and outher pipe are frozen
Old Jan 11, 2006 | 11:53 AM
92ehatch's Avatar
Default Re: Cooling System Help!! (accord99)
sounds like thermostat to me. let your car run for a bit and check the upper and lower radiator hoses, if both dont get hot then your thermostat might be messed up.
Old Jan 11, 2006 | 12:04 PM
drpapi45's Avatar
ok i Checked the hoses and only the top hose warms up...the bottom one stays cool...also i looked in back of the glove box and couldnt determine what was the motor??
jackhis
Jun 18, 2022 10:26 PM
josephcmiller2
Engine Management and Tuning
20
Aug 1, 2011 06:05 PM
simplegreenmachine
13
Dec 12, 2009 04:07 PM
sony224422
Jan 29, 2007 05:24 PM
technine
22
May 9, 2005 12:47 PM
