motor mounts for b18c1 into 96 hatch?
Old Mar 20, 2002 | 01:52 PM
fusionrd's Avatar
Default motor mounts for b18c1 into 96 hatch?
i was wondering if any of u know the part numbers for the two i believe mounts/brackets i need for thi swap? i am not keeping ac so i should not need that bracket....also on the drivers side below the cam gears i just swap that mount with the one from my civic engine? i have been to the site hybridhonda info page but they seemed to cut the rear mount and drill it out i want bolt on part#'s if u guys have them thx
Old Mar 20, 2002 | 03:11 PM
Sucka Free's Avatar
New User
Default Re: motor mounts for b18c1 into 96 hatch? (fusionrd)
they should have on that site, the 99 si rear mount that can bolt right up, if this is the mount u are talkin about.
the old directions on that site, suggest cuttin like a little bitt off a teg tranny mount? to make it fit. something like that.
Old Mar 20, 2002 | 03:30 PM
DR. ON POINT's Avatar
Banned
Default Re: motor mounts for b18c1 into 96 hatch? (def jux)
rear civic si mount, integra suplementary mounts, and stock civic block mount will work
Old Mar 20, 2002 | 08:09 PM
fusionrd's Avatar
Default Re: motor mounts for b18c1 into 96 hatch? (On Point EK)
k but 1 thing instead of a stock civic block mount he calls for a si block mount on the driver side under the cam gears(on that page with the info from trey) will i need this or can i use the one that comes on the civic motor like u said? thx
Old Mar 20, 2002 | 10:26 PM
J_SpeC_EK's Avatar
you'll need the one from a 99-00 civic SI motor..
part # 434414
Description : 11910-P30-000
here's the link to a site dat sells it..
http://www.hondaautomotiveparts.com/...=11910-P30-000
tegdude227
May 27, 2009 01:48 PM
B!^A@
Aug 10, 2006 09:15 PM
EJCivJdM93
Feb 9, 2005 04:40 AM
deviant1
Oct 15, 2002 07:00 PM
dfoxengr
Jun 14, 2002 09:52 PM
