Wheels, Tires, Brakes, and Suspension Wheel, Tire, Brake and Suspension Parts (Wheels, Tires, Coilovers, Lug Nuts, Camber Kits, Rim/Tire Tools)
Can I fit 225/45/16's?
Old Jan 11, 2006 | 03:06 AM
Boostage's Avatar
Default Can I fit 225/45/16's?
My car is a 94 EX the wheels are Slipstreams 35mm offset, Just wondering if I can fit that much rubber with that offset without looking too bulky. drop is 1.5 if that helps. pics would be appreciated if possible.
Old Jan 11, 2006 | 06:22 AM
FAST4DR's Avatar
Default Re: Can I fit 225/45/16's? (Boostage)
That's too tall.
http://www.miata.net/garage/tirecalc.html
Plug in your stock size figures and this should help you. A 225/40 or a 215/40 (smaller rotational mass = cheap FD) works.
Keep in mind, though, with a 35mm offset, this is going to push out quite a bit and you will need a way to adjust camber and a good susension setup (i.e. height adj).
Old Jan 11, 2006 | 10:35 AM
Boostage's Avatar
Default Re: Can I fit 225/45/16's? (FAST4DR)
FAST4DR- Thanks for the respond I dont want it to push out too far, so are 215's a better choice for me?
Old Jan 11, 2006 | 11:08 AM
FAST4DR's Avatar
Well, then you probably should have opted for a 40mm + offset. We run a 35mm on our ECHC car with 225/45 Hoosiers. No matter what tire you run, the rims ARE going to stick out more than a 40-43mm, but I dont think its going to look bad. Is there a reason you need to run such a wide tire?
Old Jan 11, 2006 | 11:23 AM
Boostage's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FAST4DR &raquo;</TD></TR><TR><TD CLASS="quote">Well, then you probably should have opted for a 40mm + offset. We run a 35mm on our ECHC car with 225/45 Hoosiers. No matter what tire you run, the rims ARE going to stick out more than a 40-43mm, but I dont think its going to look bad. Is there a reason you need to run such a wide tire?</TD></TR></TABLE>
I will be tuning my car for 505whp so I need a quality tire and a large contact patch.
twkdCD595
Oct 13, 2010 10:06 AM
Accord1234
Jan 31, 2008 02:50 PM
john d
Jun 24, 2006 12:05 AM
y0whuddupb
Apr 7, 2006 11:15 AM
tb3
Jul 16, 2001 08:24 AM
